JohnJTDI
Have looked at a number of older threads re: the fix for this code.My CEL comes on(have cleared couple times) and VAGCOM gives me this code. Fixes range from cutting the wires to the cat sensors and tieing their ends together(didn't work for me or should the ends not be connected as this is nothing more then a short?), installing 10 ohm or 220 ohm or 330 ohm resistor of various wattage. Looking for an update as to what works. With the 310 code does that mean I only have to deal with 1 of the temp sen(G20-and which 1 is G20? front or rear) and not worry about the other sensor(G132) as this would be a different code(312)?? 5th injector has been disabled by plugging fuel line. I also assume it got the company mod for the 5th inj under a previous owner as the car doesn't smoke and the ECU is not black..?? Is it possible to clear error codes using blink codes on this vehicle or is this only possible w/ a scan tool??
