EPA Just Deregulated Diesel Emissions Standards
gearheadgrrrl
Legal or not, sketchy as well, the newest f350 junk from ford lists 37,000 pounds combined max, with the "right options and tow package". It should be rephrased as " with the right wannabe options "
I would never do that behind a glorified kids toy with a little plastic connector keeping my electric brakes plugged in. I see plenty of disco lights at night going down the road, I'm sure the electric brakes are doing the same.
I'm sorry, that's air brake territory in my opinion, and not light duty truck chassis work, I don't care what's under the hood and cab for engine and gearbox. The farmer that does it with the 4ways flashing driving 20mph holding up a half mile of traffic needs to be respected. Not the sh1tbags taking Tiktoks while ripping down the expressway with his 4 SEMA-weiner trucks on his flatbed towing 34k# , rolling coal with rubber bands on wheel spacers.
You know it.
And don't get me started on the guys who are too lazy to earn a CDL and get proper operating authority who race up and down the highways with a one ton dually pulling an overloaded 5th wheel trailer with minimum limits passenger car insurance!
[486]
MN
02 golf ALH
heh
11k lb gvwr, 6500lb empty weight
a 5 ton load of sand doesn't even make the bumpstops touch, so it's got to be perfectly fine
kjclow
Charlotte, NC
When I was still driving my 2010 JSW TDI, (pre scandal) I could stick my finger in the tailpipe, and there was no soot residue, whatsoever. I didn't see any problem, when the scandal happened. As fate would have it, I crashed the car, on a really steep, icy hill. I never had the chance to take the advantage of the buyback. At least, I am still in one piece! ;)
I noticed that the "fix" caused soot build up in around the tail pipe as well as drop the mileage. Also took away some of the "zippiness". Parked the new subie next to a JSW while on my midwest trip. Can't believe how much bigger the subie looks!
dieseldonato
Us
2001 jetta
I have a class A cdl, im quite awear how much it sucks to run heavy with gutless. Could gross 68k with my first service truck, 250hp 3176 cat. 8L+LL. Couldn't hardly get out of its own way. 65mph down hill tops, unless you kicked in neutral. No thanks, too many hills around here, rather have a 300 big cam, turned up to ~425 if I have to run old junk. Rather just have a modern 13-15L with 13 or 18 spd. Honestly, id be fine with an Allison at this point in life. Uncles old 379 was giving him him grief, v903 cummins, around the world 13sp. He ended up renting a newer Volvo 13L automatic tri axle to finish hauling fill from onw of his customers. Every few trips my cousin and I would swap running the dozer for the dump. Took a bit to get used to, but was actually quite nice to drive. Comformable too. Way nicer then the old pete.
Not sure what youre if youre referring to the hot shot guys, or the camper people with your other statement. Either way, DOT and the state have been cracking down hard on them around here, state has even proposed a non commercial class A/B cdl for the camper/ rv people. Really I think its just fair. 90% cant drive a compact car, let alone have a clue about anything that has any amount of weight.
dieseldonato
Us
2001 jetta
You know it.
Maybe you should start to spec out medium duty trucks. 37k is still hydraulic brake as standard territory, air optional. Most tag trailers even up to 50k lbs have alxes with electric brake options, popular with the dump truck crowd. 2 less gladhands to have to worry about melting/ breaking off. When your backing into the paver or conveyer to dump.
I've seen no real reason to like or dislike the 7 way flat or 7 way round plug, one over the other. Fact is they both have issues with breaking, corrosion, wires getting pinched etc. Just kinda something that needs delt with either way. Engines and Trans are mostly the same options as in pickups, some you can option a 9L engine and an Allison transmission, or a whatever flavor of the day stick you want.
Then start specing out whatver flavor of f350-550, 3500-5500 whatver flavor of brand you like, and you'll start seeing all sorts of things changing, brakes, axles, axles ratios, wheel/tires, frames (yes frames change too, even on a 1 ton truck depending on gvwr.) Add nosium. They arnt your grand pappys 1970 gmc anymore.
jason_
michigan
2015 s wagon dsg
Recent Air is the safest. If there's an issue or a leak, you're stuck until its fixed.
Electrical Wiggly intermittent connectors get dangerous quick.
But that's overrated. Its legal to use electric over hydraulic @ 37k. I'll respect it more once inspections are more strict.
Otherwise its no different then some smo-joe rolling with a rusty brake line pin hole on his honda civic adding fluid every 10 stops.
