Sabadecade
- Joined
- May 16, 2003
- Location
- Winnipeg, Manitoba, Canada
- TDI
- 5-Speed 2002 VW Golf GL TDI, Indigo Blue
The problem started back in March. It appeared my 2002 Golf was going into "limp mode" It wouldn't happen all the time either. I checked the snow screen (found I had none) air filter and connection to the MAF. It seemed like the cold weather aggivated it as I noticed that the problem would go away after the engine had been running a while and cycled the engine off then on. Also if the car was still warm after getting home from work and going out shortly after it would be fine. Since it was spring and getting warmer, the problem kind of went away... (I suspected a vacuum leak due to this)
A couple months later... there's no question, it isn't "limp mode" as I get low power all the time, even when cycling the engine off and on again. I'm still asking myself Vacuum leak or did the MAF finally die? God forbid it's something as labour intensive as sticky turbo vanes.
I unplugged the MAF, as suggested on these forums, and ran with it disconnected for a couple of trips to and from work. It seemed to perform a little better.
I also scanned with VCDS and got the following codes:
Could the second code be because I disconnected the MAF?
I've gone through Canadian Grizzly's "Low Power Troubleshooting guide" - Fantastic by the way. I like pictures and diagrams.
Anyway, I guess what I'm asking is. Do I have enough evidence that it's the MAF and buy a new one or should I rule out a come more things first?
P.S. I found some MAFs for sale here http://www.autopartsway.ca/autoparts2/index.cfm?fetch=part~ID=2002~Volkswagen~Golf%20Turbo%20Diesel%20GL%201.9%20L4~240551
They seem to be the correct one and a little cheaper that other places. I'm just not 100% due to the difference in part numbers from other sites I've been. Opinions on these too are welcome.
Thanks for reading.
Code:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Thanks for reading.
