I want to share my experience about PD engine cut off after partly warming up (and not starting after), because it has a simple
cure. Sorry for bad english. I am not mechanic, but have some experience.
After long time spent testing fuel lines, connections, after drilling output valve from fuel tank I found air collecting in fuel
lines (inserted clear lines temporarily) when engine is warming up. Air (blow-by gasses) are pushed to fuel near injectors through
bad injector seals and possibly injectors itself. Strange that disconnecting good MAF sensor solves it frequently or I am thinking
so... Possibly only in some circumstances in function of air in fuel quantity, air pressure, engine temperature, how long tried
cranking before. Worth to try if nothing helps, it is faster than 1 minute on starter but with (good) MAF...
When gasses are collected in fuel and fuel with gasses is compressed by tandem pump, nothing bad happens. But when fuel
temperature reaches thermostatic T on fuel filter setpoint and engine temperature needle comes about 1 sector before vertical
position "90 C" (it corresponds real engine temperature higher than 75C - not real 90C) - be carefull! If you let RPM sudden drop
lower 2000, and at that moment T opens, compressed air would expand to tank but before it would be pushing fuel from fuel lines and
filter, so warm engine would die and not start. Needs priming fuel lines.
If you dont let RPM drop, pressure would be maintained, fuel effectively sucked from tank by pump and engine not dies, only short
unstability in T opening moment. So, engine dies only at that temperature!
When you started warm engine, T opens faster (so gasses are not at critical level collected because of shorter time before T
opening) and engine runs fine without T modification. Until it cools to negative temperature (actual only in winter season).
Tip: if problem persist and you can not drill T at the time, please dont push on gas pedal when engine cold - that forces blow-by
gasses to fuel at higher rates! And so with MAF connected (I think). And long cold engine idling helps for air in fuel collecting
(low heat, longer time T closed). Problem more actual in lower temperatures because of longer T closed time ant more advanced (and
longer) fuel (and gasses) injection.
Real simple cure is to drill 1mm hole in thermostatic T in/out ports through, letting to pass blow-by gasses to tank in all
temperatures (through hole, when engine is cool; through open T when engine hot). It is all. No problems after that. Bigger hole
would be bad because of fuel temperature drop in warming up stage. 1mm is sufficient, letting about 1 l fuel in 1 minute through
(if on higher pressure side, tandem output with T closed - tested). That cure I have read, but here are my explanations of process.
And about hard cold starting because of air in fuel (not blow-by at this time): air sucked to fuel lines past the same injector
seals (?) or other weak points - only when fuel in tank cools down to negative temperatures (some negative pressure in tank air?) -
when engine is long time shut off. Hard starting after long trip with near empty tank (in winter)- because of that suction to
tank, when air in tank heats and cools in cycles.
Cure - mounting cut off electric valve in return to tank fuel line. This not passes fuel to tank (when engine shut off only), so
no air in lines after cold night. When ignition turning on, valve must open. Be careful - valve must pass fuel when engine is
running and hot. Fuel temperature must not exceed max limits. Valve must be operational. Good choise is brass valve with emergency
manual open function (from gas equipment).
Possibly- new, not used fuel filter thermostatic T closes (slowly, when engine shut off and cools) - so good that build some
vacuum in tank (cools more quickly than T) stays closed from return fuel line and fuel stays in lines. But old, used T has more
free play inside it and with slow vacuum build up does not close fully (there isn't any tandem pump pressure). So air could be
sucked to fuel lines. That is suggestion, needs testing.
My 2000 1.9 TDI PD has no fuel lift pump in tank. Lift pump would be usefull for light cold starting (no need in electric valve in
this case). But trapped air in fuel system stays there all time till engine and fuel heats up to the moment when T opens. Fuel with
air will circulate through fuel filter with or without in tank pump (if blow-by gasses accumulates). Only new tandem pump possibly
could deliver normal fuel flow at the T opening moment (worst scenario), but not in all cases. Air still is there. Small hole in T
could be made from factory.
Possibly you have air in fuel.
