The mount must be removed (or at least moved out of the way) on both an ALH and a BEW. You don't specifically need an engine support beam - a floor jack under the engine will work just fine (use a board, etc. to protect the pan).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
