Don't mean to highjack this thread, but I had a very similar problem happen to me today, only the "stumble" was so bad it felt like a cylinder wasn't firing. Very low power, very rough running at all rpms, incredibly rough idle, barely made it home (or at least it felt that way)!
As soon as I got home I shut it off and restarted, the same terrible idle/shaking was there.
However, after about a half hour of clearing out the garage so I could get it in and up to work on, I went out and started it up.... idle smooth as can be. Any thoughts?
Car is a BRM w/228k miles, malone stage 1, SMF, EGR Delete, Colt Stage II Cam/Lifters
I plan to run a full VCDS scan, and check torsion and injectors tomorrow. I know the turbo actuator is bad, and have just been driving around it. I'll plan to try the zip tie mod too if nothing else jumps out at me. Also plan to advance the timing as I've read that might be a fix for this too.
Any other things to look at?
Anybody have any other thoughts?
