TB
With the glow plugs removed, in neutral, I can't rotate the engine using a socket on the crank. When I crank it, the starter can't turn over the engine. Replaced the starter, still can't move the engine.
I lifted both front wheels off the ground, put it in gear (tried all forward gears) and the wheels just spin and the engine won't rotate. Timing belt is ok.
With the wheels just spinning, I'm starting to think the clutch came apart.
Hope this explains my situation.
Any thoughts are welcome..
