TimmyCee
2015 Jetta SEL 6 speed manual- 72,800 miles, is having an intermittent engine shudder in all gears, with no codes. I first noticed it in 5th gear while gently accelerating around 55 MPH. It then began occurring randomly in all other gears/speeds as well, most noticeably when pressing the accelerator; I sometimes feel a quick RPM drop off while sitting in neutral too, but its gentle as I'm obviously not moving. The best way to describe what it feels like would be if you pressed the clutch for a split second and felt the car buck. RPM seems to drop when this occurs. Note: This is not occurring while shifting, but rather while the car is already in gear. I had to leave the car with the dealer and have the technician drive it a few days as you never know when it will occur. It seems the most likely conditions for it to occur are on the second drive of the day, after the car sits for an hour or more. Technician is thinking pressure plate or flywheel, but I am not convinced the symptoms match. VW of America is suggesting a transmission teardown, which my extended warranty would not cover unless an internal part is to blame. I am not mechanically savvy, so please respond accordingly
