The water pump isn't going to do anything. You probably have a leak at the head gasket, valve cover gasket, camshaft module, etc. Or a crack in one of those items. I doubt it is the block, as even a crack near the water pump would just leak coolant, and not oil.
And since it is spewing all over, and it seems to be (from your description) heat cycle related, it probably is not an oil pressure type leak.
I would want to remove the timing components, remove the inner cover, and inspect what is underneath. It is obviously coming from BEHIND the hole in the inner cover where the water pump passes through.
There is also a sealing cap on the end of the camshaft module it could be coming from. The belt drives the exhaust cam, so it has a regular seal. But the intake cam is run via gear off the exhaust cam, the cam itself does not stick out through the front of the module, so they cap that machine hole off at the front.
