Benjamis
Car fresh off timing belt job and test drives. I took it to a job the next day, drove 26 miles, all was well. Finished the job, drove to the next job 4 miles down the road. Started working, went to my car to grab a few things, noticed some oil on the road. A trail of oil. No trail of oil in front of my car. A huge puddle under the car. Definitely no oil when I backed out of a spotless cement driveway 4 miles ago. Zero oil on the dipstick.
No oil light or buzzer, no indication of anything wrong whatsoever while driving and pulling up to the parking spot on the street. All belts and pulleys are slathered in oil. The passenger control arm and wheel are slathered in oil. The tow truck didn't show up after waiting 2 hours and wouldn't respond to calls. The second one cancelled. The third would be more than a 2 hour wait. Long miserable day working and feeling ill. Didn't have energy to move or care. Caught a ride home. Had a sick day the next day.
Surely you guys know what this is, before I get it towed home and tear into it again, being the lucky guy I am to still have a salvageable engine after essentially 3 tows in the last 800 miles, not to mention springing leaks in IP seals. I guess I was lucky, back in the day, being able to drive 1000 miles before another fix. I keep thinking there is light at the end of the tunnel.
EDIT: I came to find out that the spotless cement driveway was not so spotless after all. It had a huge puddle of oil and two trails, one for when I pulled up, and one when I reversed out. I suppose with the road construction there I was fixated on the mirrors while backing out and didn't even see the oil until the next stop. However, my driveway at home has no oil on it or where I park. There was no leak after a 10 mile test drive after installing the timing belt, or sitting there with the engine running for minutes running VCDS. So it sprung a leak at some point on the 26 mile drive to a job.
