veedub_tdi
- Joined
- Jun 29, 2001
- Location
- Scarborough, Ontario
Hey folks, I have an AHU TDI and since the beginning of the year the car was noticeably loud at idle. When comparing it to other TDI's there was a definite difference. Well recently I had to go into the dealer to get a new glowplug, and they told me that the loud idling was due to a tensioner that needed to be replaced. Apparently this is a very common part they replace, on our style of engines.
I thought I would share this with you, just in case some of you have the same problem.
If you look at the serpentine belt, there is a tensioner (idler) pulley, that presses against it. If you follow the arm which it is connected, across to the right to the end of the mounting bracket (your alternator is mounted to this bracket), you will see the spring tensioner. Its black, its held together by two 6mm hex bolts on the sides, and one 5mm in the middle. I was told that the spring inside tends to wear out which causes the idler pulley to shake violently at idle, when its supposed to be pushing against the serpentine belt.
The part costs $62 CDN (or something like that +tax of course). I've replaced it and the car idles sooooo quietly now
its like its brand new all over again
Hope this helps someone out there
