rackaracka
- Joined
- Nov 15, 2001
- Location
- Monroe, NJ
The vehicle data: 1998 NB TDI, 5 SPD, 11MM, Sprint 442 Nozzles. 11,500 miles on rebuilt motor. (Frank06 head and block rebuild, assembled by a hack - but he did have the correct tools including VCDS) I re-did complete timing belt job when purchased. New 11MM pump installed 10k ago, purchased from BoraParts when the 11MM that came with the car (prothe) grenaded.
How does it run? Engine starts and idles beautifully (Occassional SDS that requires a blip of the pedal when stopped), Pulls hard, No power issues, boosts to 17 when pushed and holds 13.5. Stock ECU for now.
What's the problem? During cruising in 4th or 5th gear, when trying to hold constant speed and RPM between 1800 and 2200 - engine starts to hesistate or studder - like a miss. Tach stays steady, boost gauge (Tied to MAP sensor) flutters from 3PSI or so to 0 - bouncing around in synch with the power loss. Pushing the go pedal makes everything fine - boost climbs smoothly and power is excellent. 11,000 Miles on fuel filter - current setup has no thermo-t. Solid fuel lines so I can't look for bubbles. Problem exists using the pedal as well as when using cruise control. Timing and IQ are perfect. Car has no fault codes. I have VCDS. Any thoughts or recommendations on this problem?
Figured it might be a MAF Sensor starting to degrade so I swapped it with a new one - same issue still exists. Now concerned about any long distance / highway trips.
