Hi all,
Please need your help!!!
Tried everything and dont know what else to do. Engine starts without problems, but as soon as its hit 1200rpm car star jerking, loosing power, shakes till 1400 and then fine. Took it to the garage few times and no help. Checked faults code and nothing stored in ECU, but when I scrolled through the measuring blocks injectors values on each injectors travels up and down at this rpm's. As soon as past 1400 rpm all stabilize and hold nicely. Also MAF reading seems odd, up and down. Air intake checked from filter back to engine, fuel line the same and nothing odd what would catch my eye. No black or white smoke
What has been changed:
- new injectors,
- new injector loom,
- new fuel filter,
- new tank/lift pump,
- new throttle body,
- new MAF sensor,
- new ECU unit,
- new n75 valve,
Any idea what can cause this mystery, please?
- new injectors,
- new fuel filter,
- new MAF sensor,
- new ECU unit,
- new n75 valve,
