Engine Hiccup
PineRidgeTDI
Montana
2015 VW Golf Sportwagen 2.0 TDI s
When I am driving my 2015 Golf Sportwagen TDI s I will get a drop off in engine RPMs. I would describe it as a hiccup while driving as the RPMs fall off and then come back up. It seams to happen while driving at highway speeds mostly. It has happened a few times while driving in town. Since it seams to happen most often at highway speeds I can't determine if is happening while the car is doing a regen cycle or not. I recently changed the oil, fuel filter, and air filter. It was in the VW dealership for the 150k service and they did not have anything to report.
The car has 156k, and is not showing any CEL.
Any help on the issue would be much appreciated.
pedroYUL
MI, USA
2015 Passat CVCA; 2015 GSW CRUA; 2012 wagon CJAA; 2004 wagon BEW
Read here:
tdidieselbobny
Stafford,NY (WNY)
Wish it was easier to load a video here like on other sites. I just ordered a crank position sensor for mine- part # 04L-906-433-B . Got it for $58.85+ shipping from Ancira VW in Texas(VW Direct Auto Parts.com). IDParts didn't carry it. Maybe they should....
PineRidgeTDI
Montana
Thanks for the input I ordered the part, will put it in when it gets here, I live in Montana.
tdidieselbobny
Stafford,NY (WNY)
I just got the tracking # for my CPS. I'm gonna wait to put it in. When I took skidplate off, I wiggled the wire for CPS that goes by the oil filter housing. It didn't look or seem to be pinched, but haven't had a hiccup issue since🙄
Mike_04GolfTDI
Richmond, BC, Canada
Mine: 2019 Golf R DSG, Wife's: 2015 Golf Comfortline TDI
Another one… It’s like the 2015 crank position sensors are all failing now.
That link posted by pedroYUL was from when my wife’s car developed this problem last year. VW dealer was not capable of fixing it even after being told what the problem was.
If you have VCDS you can test the sensor, but you’ve already ordered one so you may as well just try it, and most likely that will fix the problem.
740GLE
NH
any soft codes stored for these failing CPS?
or is it primarily "driving feel" as a precursor to fully failed units?
pedroYUL
MI, USA
IMO Mike had a failed CPS and he had no codes at all, nothing stored
740GLE
NH
yippy another thing to keep an eye out for.
tdidieselbobny
Stafford,NY (WNY)
I had the engine hiccup today for first time since I wiggled wire a few weeks ago. The only code stored in VCDS was due to the stalling with flashing glow plug light, a P02149 fault. CEL did go out by itself, but I made sure not to clear it.
tdidieselbobny
Stafford,NY (WNY)
Today was the worst day of the stuttering. Going 30mph it stalled. Coasted to side of road, shut ignition off, started right back up. Still did the stuttering for a few minutes, eventually cleared up. Hour or so later on way home from a Subaru dealer, started the stuttering again. This time the ESC light came(said something in the information center), then the TPMS light came on, then a flashing glow plug light. Didn't stall or trip CEL this time. But car did seen like it was in limp mode, didn't accelerate properly. Got it home, shut it off. Started it back up, all lights went out. Decided to drive it to dealer. Drove normal like nothing was wrong for the 40 mile drive. I showed the service manager video I took of the flashing glow plug light, ESC and TPMS light on, and the lack of power. I also told him about the P02149 code that is stored... we'll see if they find anything. I'll post updates when I get them. Saw a 6 spd 2023 Crosstrek I liked at the Subaru dealer when I made appointment for service for the wife's Crosstrek...also just read this is last year for manuals in the Crosstrek..
tdidieselbobny
Stafford,NY (WNY)
Update- dealer pulled some codes, and they ordered a crankshaft position sensor. Advisor also said it’s covered under Dieselgate warranty. They just got part in(overnight shipping)said should get to it tomorrow . Fingers crossed
super1
NY
none
I thought you ordered your crank position sensor in February did you not get it then?
let us know what happens with the one from the dealership
740GLE
NH
That was prob his fall back if the dealer wasn't going to do it under warranty.
tdidieselbobny
Stafford,NY (WNY)
Yeah, I ordered and got it last month. I was gonna do it once it got warmer, but the episode on the 4th had me take it to dealer, only code stored was P02149. They were able to diagnose/test sensor and their test plan said to replace the crank sensor as a test. Picked it up today, no charge thanks to Dieselgate warranty. I'll keep ya posted if it comes back or not....
super1
NY
none
That’s the problem with that sensor a lot of times it doesn’t throw a code
Yes, let us know how it goes
Mike_04GolfTDI
Maybe they went and read my thread on the subject to figure out how to test it. LoL.
My dealer had no clue.
pedroYUL
MI, USA
whats the p/n of the crank sensor?
bmwM5power
Rochester NY
15 GSW TDI S 6MT 02 JETTA TDI GLS 5MT 15 GOLF TDI SE 6MT 15 GOLF TDI SEL DSG
Do you need one or gonna have dealer replace it? If you need one, I have the one I ordered -$70 and I'll meet up with ya somewhere around Rochester...
i dont need it yet I was just trying to be a little proactive
tdidieselbobny
Stafford,NY (WNY)
I got lucky and car ran like sh*t for quite a few miles including limp mode, didn't throw a check engine light the last episode like it did previously. But luckily Basil VW in Lockport was able to diagnose/test/pull codes on their computer. I've heard some other dealers weren't able to do that. Also depends if you still have Dieselgate warranty left. Not sure how Ide or Bob Johnson(formerly Dorschel) service departments are-I used to use Dorschel, but I heard when Bob Johnson took over that there was an exodus of mechanics there...
tdidieselbobny
Stafford,NY (WNY)
Welp, we may be back to square one :mad: :mad: :mad: . Past couple weeks I've been having occasional long first starts(in morning, or leaving work). It cranks for a good 3-4 seconds and not the instantaneous starting I'm accustomed to. Then tonight about 2 miles from work on way home(in a 30mph zone). I felt a slight hiccup, then glow plug light only started flashing- like limp mode, no acceleration for about a tenth of a mile then it died. Coasted to side of road, shut off ignition, fired back up like nothing happened. Fine all the way home. I actually already have dealer visit scheduled for tomorrow morning to check over car before I the Allstate extended warranty I bought when I purchased car runs out next month.... will keep updated....
super1
NY
none
I thought that Cranks Sensor would have fix it :(
Did you happen to scan for codes now?
tdidieselbobny
Stafford,NY (WNY)
Didn't scan for codes. Dealer did test injectors and said the #2 wasn't working correctly(can't remember exactly what advisor said, and didn't get any paperwork as it's still an open repair) -they ordered one, and taking it back next Thursday morning for install if they get it. Covered by Dieselgate warranty, and don't have to pay the $179.95 diagnostic charge. Once they install it he said they will test all the injectors again.
super1
NY
none
Ok sounds good
Please keep us up to date on this
