I have my 1.9 engine die this morning on my way to work . It started rite back up and hasn't done it again since . Is there anything it could be ? Possibly clogged fuel filter ? Tnx for any input
Fuel filter, or if it’s the 02 in your signature check the 109 relay, if it’s the old black one change it to the new grey one, or crank sensor / crank sensor wiring.
Basically it shut off on my way to work on the freeway going about 65 . I pulled over and started it and its been running fine ever since . This happened on Monday btw . No CEL light on or anything. Oil level was a little low , seems like I have to add oil every so often .
Yep, well, back to the OBD then. At least that will give you a possible clue as to where to start looking. If nothing is found, then the guessing based on pattern failures starts, and that could be a lot of things.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
