Hi, my golf died on the highway, i felt some sluggish power, managed to pull aside, engine got less and less responsible, and finally died.
it cranks but no ignition, i tried starter fluid, and it fired.
my first thought was lift pump, i bypassed with 12v directly it runs and deliver fluid, i allready tested the pressure and i got 4 psi. tandem pump, i opened that, it looks fine,
few months back the timing belt jumped some teeth cause of one of the wheels loosened from engine, i rethreaded the engine with new bolt, timed it and it ran perfect up to now.
i don't know where to look for any more cause of the non firing engine. i got no code in vcds.
timing are still good. i tried to unplug the camsensor white and black plug below intake. . new fuel filter also installed.
since it fired with starter fluid, i don't suspect cam followers damage from cambelt failure, but i dont know. workshop told i was lucky because the followers usually broke.
so i need some advice
right now i still haven't mounted back the tandem pump due to lack of gasket on hand. im quite shure if i reassembly back it will still not run.
right now im gonna test the flowrate from lift pump, i do not know if the volume matters a big deal,
thanks.
edit.
new lift pump solved the issue, thanks to the contributors for solving this
thanks.
edit.
