Heading to work this AM car was running fine, abut 30 miles into the drive I stop at a stoplight and thought I smelled diesel fuel, about a mile later the engine dies and I coast to the side of the road, get out and open the hood and diesel fuel is all over the engine, pull the engine cover and diesel is dripping from the bottom of the cover, I do not see anything leaking.
I checked the supply and return fuel connections as the supply connector popped off 2 weeks ago in a parking lot.
Only code was for low fuel pressure. Tried to crank but noting but a click until I cleared the code, then the engine started again and then glow plug light started flashing so I shut it off and called a tow truck.
As we are getting back on the highway on the way back home I see the stream what I assume is diesel down the road.
Get home and unload the car and try to crank again so i can put in the garage and no luck and the low oil light comes on?
I check the oil and nothing is showing on the dip stick, first thought is the tow truck cracked the oil pan with the chains, but nope, just a coating of oil and diesel on everything. Drained the oil and it has maybe 2 qts of oil. It was full the day before.
Where did the oil go? And how could that be related to the fuel everywhere.
