crisp006
Hi guys,
so I did my timing belt with my dad not long ago, and I didn’t think of it at the time as I (and it would now appear evident him too) lack much automotive knowledge, but now I’m wondering whether what we did whilst working on the timing belt could’ve damaged the internals of the engine.
When trying to line up the flywheel at TDC we found ourselves overshooting the mark (just a little) and then cranking the engine in reverse to get it to line up. I’d be eyeballing the flywheel TDC mark while he’d rotate the engine at the crank bolt with a breaker bar.
we had to do this a few times to get it to line up the first time we did it, but then did it a few times again when the flywheel mark would be off TDC after tightening the crank lock. And a few more times when the flywheel was off after tightening everything up.
overall I’d say we rotated it in reverse 20-25 times. However, the vast majority of that is accounted for by tiny adjustments (less than 5 degrees I’d say) after doing the initial larger adjustment in reverse because of overshooting the TDC mark (in which case we’d crank the engine in reverse by 10-15 degrees at most).
I know this probably sounds dumb (though I’m willing to bet I’m not the only one whose done this and that it’s much more common than one would think). Though I’ll say that I didn’t see any mention of this in the TB guides (though maybe it was thought it’s a given that one should not rotate an engine in reverse).
can anyone who is knowledgeable about these engines chime in? Am I overthinking this or is it likely serious (or minor) damage was caused? I read online elsewhere from a few sources that in general, one would have to crank an engine more than 3-4 revolutions in reverse to cause any problems. I assume that would be total, uninterrupted revolutions, not degrees of rotation in aggregate. Correct me if I’m wrong.
please feel to free to chime in guys.
Thanks.
the car is a 2000 Jetta TDI. ALH engine.
Thanks.
