tperretta
The car has been a bit sputtery at times over the past few weeks. Acts like it's dying out... and sometimes it will die when at a light idling. It got progressively worse over the 3 weeks and sometimes it would cut all power as if the motor was completely off (still in gear but acts and sounds the same as if you run out of fuel). A few times I had to restart it when It did that and other times it would jerk the car as it fired back up all of a sudden.
Now, no start and the clear fuel line is empty. I just replaced the fuel filter in attempt to fix this issue. I filled it with diesel and cranked the car many times with zero luck (cranked a LONG time for some of those attempts). Still empty fuel line.
I just ordered a new Tee fitting and o-rings to try next but i feel like that wouldn't leave the line empty after at least 5 minutes of cranking the engine. The next thing i'm going to try is the fuel sender unit. Is that a logical next step?
I have no leaks on my IP. Nothing visible anyways. Is there anything else i should check while im trying to narrow down the cause of this?
Thanks,
Anthony
Thanks,
Anthony
