nicklockard said:
FUB, I'm a bit confused. If IMP < EMP, by definition isn't that surge territory?
Or are you saying that that is simply indicative of lag?
Sorry for my ignorance. Can you plot differential [EMP - IMP] and EMP/IMP, ratio? Or give raw data and I'll do it.
Why is the vag log data 2 seconds lagged? I missed that. Can you do anything to time-correct it?
Noted: TIP is under 2 psi vacuum for almost all of your accelerative run. That is a suprise since you are running a 3" custom TIT, isn't it? I wonder where the restriction is coming from...airbox/airfilter?
Do you run your stock intake snorkel, or have you removed it?
IMP's can be > EMP's without surge: Surge is a function of shaft speed and compressor differential pressure and has nothing to do with EMP's directly if I understand correctly. Remember these are not positive displacement air pumps/motors - they rely on accelerating/decelerating the gasses so if you can't spin the wheel fast enough to accelerate the air to a high enough velocity that it will continue moving out of the compressor housing, then it will surge. The exhaust side is a bit different with the variable geometry as the vanes change the angle that the incoming air contacts the exhaust wheel. The same "EMP" can have significantly different ammounts of energy transfer to the wheel depending on what angle the gasses hit the wheel. When the vanes are just opening there is more restriction but the gasses hit the wheel at the outer perimeter and ~perpendicular. The EMP's are measured before the vanes so that pressure is not necessairly what is acting on the exhaust wheel. I don't know how to measure the pressure after the vanes but before the wheel.
I did not notice the lag in the VagLog data until I posted it. I can subtract the difference between where the RPM's start to fall and where the IMP and EMP's fall (assuming these points correlate) and re-plot/post it. For some reason my trigger's must have a delay in them or something or I just screwed up the merging somehow.
IMP-EMP's are in the plot (purple) unless you specifically want EMP-IMP which I can do if you want. I've got EMP/IMP data (or the other way around - don't remember off hand) but did not plot it as the graph was pretty busy as it is. It did not exceed ~2.0 IIRC
My guess on the TIP is the airfilter is the main restriction, but I don't know. I have the snowscreen removed, but otherwise stock. This is measured before the MAF and my 3" inlet pipe so the actual at the turbo will be even less (absolute) pressure. The MAF readings were pegged at ~1275 mg/stroke early on in the run and tapered off as RPM's increased.
This is all about mass airflow as volumes don't make much difference due to the Pv=NRT thing and we are dealing with energy transfer here. I don't think IMP's or EMP's or their relationship to each other have much to do with smoke. That's just mass airflow and fuel injected, primarly, along with injection timing and RPM's, secondairly (sp?).
I hope I answered all your questions (and a few others). I'll try and do some more runs on my car since everything is hooked up (maybe put in my new air filter) and try and work out some of the bugs (filter the EMP and IMP signals to reduce the "fuzzy" traces, trigger synchronization, different driving conditions, downpipe pressure, automated VagLog data merging etc).
I think what we really need is a GTG (when or where it's warm) with a variety of cars with various equipment where we can take a bunch of measurements and do some comparisons (R32 Airbox/MAF, OMI, FMIC/SMIC's, Downpipes, Turbos, etc). We'd also need a nice piece of road where we can do runs on or a controlled load dyno - Hey DGD, what do you think about another GTG in April
? (I say that because it's only ~1hour away, I'm selfish and I probably can't drive too far to another GTG since the last one kept me away for 20+ hours
which made for some interesting home life for a few days after).
