Emissions fault, MAF sensor
Razghost
Luton, UK
2.0 PD, BRT
First off sorry if this is the wrong section but since it's throwing a emissions fault it makes sense.
I have a 2.0 PD engine BRT that shows emissions workshop on the dash. Car runs great but will only give me ~40% throttle.
So I did a obd scan, cleared the faults but the maf sensor remains "low input". So I swapped out the sensor and still the same. The live data from my scanner shows the maf reading as 0. This leads me to believe the the wiring to the sensor is broken.
However I have no idea how to go about checking this. I can't find a wiring diagram or the pin outs for the ECU to check if none of the wires are broken. If I follow the wires it just goes over the air box and then into a bigger loom. Both have a plastic sheath.
Any help as to where to go from here would be appreciated
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
erwin and many other sources will have wiring diagrams for your vehicle
Pay for the manuals you need, or pay others with the knowledge to do it for you.
Razghost
Luton, UK
2.0 PD, BRT
Erwin doesn't list my engine, can you name the "other sources" where I can buy a manual?
I would pay someone to do it but when asked they said if after they buy a genuine maf sensor and find the problem still there they would replace the loom basically making the repair cost more than the car's worth
TurboABA
Kitchener, ON
What are you talking about?
Did I just manufacture the visual I showed you?
Do you know anything about what you are saying?
If you know the vehicle that you got the engine from, why are you referencing a document from the NA market? Was there a 2006 Sharan sold in the North American Region?
And you might've know what vehicle you had, but I don't read minds!
Razghost
Luton, UK
2.0 PD, BRT
Oh bugger I know what did, I clicked the first link on Google and took me to north America page.
Sorry for wasting your time I appreciate the effort you went through
