Exmerctech
Im certainly not saying this system doesn’t work, i’m just trying to understand how it works.
so the svo is heated up in the filter and heat exchanger but does all the svo in the pump congeal/gum up/solidify when left over night?
Are they saying the glow plugs are so good that it’s not an issue?
also is fitting a diesel powered pre coolant heater (like the webasto heater found on land rovers) to heat up the engine and fuel heat exchanger a better idea.
has anyone ever fitter a Emersion heater in the tank or one of the silicon heating matts around the tank.
I’ve have a twin tank system but can see the be if it’s of a single tank just not sure if it really works?
