Hi,
I have collected together some parts to get on with a conversion for my Elise with hopefully about a 200bhp PD engine.
ATD PD engine with loom and EDC15+ ecu
6 speed gearbox
530d turbo
pd130 injectors
The Elise currently has a b16 turbo engine which has recently catastrophically failed due to a fuel pump failure. So I thought a Diesel engine would be fun in such a lightweight car approximately 700kg.
What i currently need is a schematic to get the engine running, I have searched around but cant find anything useful. I am an electronic engineer so the wiring is not a problem once I have the schematics.
I have already removed the immo from the ECU and hopefully the EGR but I will only know if that is successful once it has been run.
The engine mounts to fit the engine are basically identical to a common conversion of putting the VAG 1.8t engine in Elises which I have been involved in previously.
Phil
6 speed gearbox
530d turbo
pd130 injectors
Phil
