Alchemist
OK, it makes sense on how to hook it up.
That's the part I'm confused about.
This should either help you understand or make you give up.
This is a partial circuit of my remote start/stop generator. When in run, the relay is energized through the resistor and supplies power to the fuel cutoff solenoid. The relay is only 6 volts in a 12 volt system, so there is a resistor of equal value to the relay coil to drop the voltage in half. to stop the engine, the hot side of the relay coil is grounded through the stop switch. Because there is a resistor, it does no harm to ground the hot side, the relay drops out and the engine stops. The analogy is apparent to me, so I hope I haven't lost you with this.
Paul
