jimbote
Certified Volkswagen Nut
OK...In my never ending quest to fully integrate my tacoma TDI swap I have come across yet another issue that requires the input of a electronics guru.... on my swap I'm using ecm Pin 24 of 121 for the CEL signal straight to the toyota's CEL....one side of the CEL gets 12v from the truck harness the other side relies on a ground signal from the VW ecm... what I have discovered is that using this pin causes a reverse operation of the CEL ...ie: when I have a DTC the bulb is NOT lit ...when I have no DTC's the bulb is lit!! ...funny huh? ...so what I need is an electronic circuit or a component that would act much as a two position or five terminal n/o, n/c relay to reverse the signal and give me a CEL at the appropriate time ...any input would be greatly appreciated and acknowledged in the swap forums....tia!!
