Hello all, first i know y'all love to see the full scans so i have attached it however some of the issues i am going to list are not in this scan due to beign disabled by my tune but are related.
I have recently acquired this project car and would love to solve a multi system issue in relation to one wiring issue or at least i think. I got the car a couple months back and have been slowly working through its issues and have come to a stopping point. initially i would have an engine light due to glow plugs so i had them disabled for the time being (to pass safety where im from) and the other main issue i have been having was when i was driving until it was warm was no issues but once it reached operating temp the engine would almost stutter when accelerating and cruising idle would also be an issue. Ok so i found it to be a fuel temp sensor issue so i unplugged it and issue basically went away until i was driving and it would still do it but only when driving now. Rarely and randomly it would also just die start it up go again no issues. Okay so now to today. I used it in the morning to move some still cars around and finished with that no issues parked the car came back and now i have all the issues shown in the log. so i started to dig into it to looking into replacing the crank sensor well that is what led me to thinking everything is related issue, glow plugs, crank sensor, engine speed sensor etc are all in the same wiring harness run.. so i am wondering if anyone else has seen an issue like this and what might be the best course of action . ground ? something else ? wiring chaff locations..?
i also have an issue where my cluster resets every time the car shuts off but im not assuming it is related but i thought i would mention it.
Code:
Saturday,09,November,2024,12:34:31:03282
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: 3VWST31K36M655256 License Plate: OWEN
Mileage: 379960km-236096mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST31K36M655256 Mileage: 379960km-236096miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: XXXXXXXXXXXXXX
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 6393A3A277557532221-8036
VINID: 0E69E390305B0C6746145085182457A4D9
4 Faults Found:
001618 - Sensor Reference Voltage B
P0652 - 000 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 19
Reset counter: 255
Mileage: 379965 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:06
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00000000
000802 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 379965 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:10
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.64 V
Bin. Bits: 11001100
Idle Stabilization: 0.0 KW
RPM: 0 /min
009572 - Turbocharger Boost Control Position Sensor Circuit
P2564 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 379965 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:44
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 2.9 %
Absolute Pres.: 979.2 mbar
Absolute Pres.: 183.6 mbar
Duty Cycle: 101.6 %
012295 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 273 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 9.65 V
Bin. Bits: 00001100
(no units): 32.0
Readiness: 1 3 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 40D94C2EC6830E2A1F3-8014
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DG
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 6C81C89E9A8B3A4A93B-8038
2 Faults Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
01317 - Control Module in Instrument Cluster (J285)
008 - Implausible Signal
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000117944
Coding: B0018E234004180000140000001400000008730B5C
Shop #: WSC 93246 999 52548
VCID: 2A0D0E8650FFE47A217-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 93246
1 Fault Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 2
Fault Frequency: 7
Reset counter: 109
Mileage: 379965 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1T AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD032V92
Coding: 0012628
VCID: 2E0502966C17885AFDF-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME0A66585CN
Subsystem 3 - Serial number: 6342MSME0A66306AD
Subsystem 4 - Serial number: 6351HSME07524E67C
Subsystem 5 - Serial number: 6361HSME07654333%
Subsystem 6 - Serial number: 63727SME071F5D38C
Subsystem 7 - Serial number: 63827SME072B447A6
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000021
VCID: 78A9E4CEDED386EA673-802C
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 852 D
Component: KOMBIINSTRUMENT 3HL 1012
Coding: 0023303
2 Faults Found:
004 - No Signal/Communication - Intermittent
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105608829E
Coding: 2D3F0B40071002
5 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 69
Mileage: 377401 km
Time Indication: 0
Date: 2000.00.00
Time: 00:02:58
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Reset counter: 69
Mileage: 377401 km
Time Indication: 0
Date: 2000.00.00
Time: 00:03:02
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Reset counter: 109
Time Indication: 15
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 109
Time Indication: 15
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Reset counter: 69
Mileage: 377591 km
Time Indication: 0
Date: 2000.00.00
Time: 00:23:14
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36352AF69447B09AB5F-8062
1 Fault Found:
00939 - Mirror Adjust Motor; Drivers Side (V149)
012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323D16E6782FACBA997-8066
2 Faults Found:
Freeze Frame:
Mileage: 9920 km
Temperature: 8.0 C
Voltage: 11.80 V
Voltage: 11.70 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 1B7803283F2D050F880F048051A0
Shop #: WSC 93246 999 59127
VCID: 74B1D0FEC2BBE28A4BB-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B27F2934D4992AE9-8062
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313F19EA7D2997A2E0D-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D07059A6111F342C45-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 01:14, VBatt start/end: 12.1V/12.1V)-----------
