in the last couple of days my JSW started acting strange: lights coming on for no reason, doors wont open, key wont turn. I resorted to unplugging the battery and after that things appear to work better.
I cleared the codes but central convenience issues still happening. Is my CU going out? Expensive item to replace I hear....
Saturday,11,April,2015,12:44:10:53003
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 62 65 72
Mileage: 108600km/67480miles
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: 12H01--- Serial number: VWX7Z0I124C0GP
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 3FA3AAE56EB2B7E6A2D-806A
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1953
Revision: 04844002 Serial number: 00000811130854
Coding: 0000020
Shop #: WSC 00028 000 00000
VCID: D1871C5D4826B196C49-8084
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B600D492400FD880F06EA921E0042B000
VCID: 75CF08CDDC0E3DB6B81-8020
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JJ HW: 1K0 820 047 JJ
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 75CF08CD1C0E3DB6B81-8020
1 Fault Found:
01296 - Sensor for Vent Temperature; Center (G191)
007 - Short to Ground
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000009298417
Coding: 04898F2340041500070000001C000000000873075C000120000000000000
VCID: 3245F3D1ADE06A8E5D3-8067
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 050209 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 0K AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08L391
Coding: 0012363
VCID: 6DFF20AD745EF576401-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME41052F143
Subsystem 3 - Serial number: 6342MSME4330563EA
Subsystem 4 - Serial number: 6351HSME1B452579B
Subsystem 5 - Serial number: 6361HSME1B2E0871C
Subsystem 6 - Serial number: 63727SME1B600D5B7
Subsystem 7 - Serial number: 63827SME1B60146D3
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001034
VCID: 8225E311DDC09A0E0D3-80D7
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0005000 Serial number: VWX7Z0I124C0GP
Coding: 0007203
Shop #: WSC 20129 444 64522
VCID: 3957C4FD709699D69C9-806C
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 205
Mileage: 108424 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:39
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 205
Mileage: 108443 km
Time Indication: 0
Date: 2000.00.00
Time: 19:20:47
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 101208F2000424
Coding: ED807F07001002002002
VCID: 3753C2C546828FA66AD-8062
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2EGJ03
VCID: FDDF90EDA43EE5F6701-80A8
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2418
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000515189128
Coding: 0001205
VCID: 6FC33AA57E52076672D-803A
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 70 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C79EDA98FC43C7E17F-8079
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 DA HW: 1K0 959 433 DA
Component: KSG PQ35 RDK 052 0225
Revision: 00052000 Serial number: 00000000000000
Coding: 1390078852830C3E2904058FB0880F0488DC00
VCID: 72C533D16D602A8E9D3-8027
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 21
Reset counter: 165
Mileage: 0 km
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08121601350503
Coding: 0001204
VCID: 70C139D9636C189E6B7-8025
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003721937
Coding: 0001168
VCID: 76CD0FC1010836AEB1B-8023
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0453
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003761699
Coding: 0001168
VCID: 77D302C506024FA6AAD-8022
End ---------------------------------------------------------------------
Chassis Type: 1K0
Coding: 0050078
Coding: 0000020
Revision: 00H35001
1 Fault Found:
Coding: 00038805
Shop #: WSC 00066
Coding: 0012363
Coding: 0001034
Coding: 0007203
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 205
Mileage: 108424 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:39
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 205
Mileage: 108443 km
Time Indication: 0
Date: 2000.00.00
Time: 19:20:47
Coding: 0001205
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Mileage: 0 km
Time Indication: 0
Revision: 00H15000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 21
Reset counter: 165
Mileage: 0 km
Time Indication: 0
Coding: 0001204
Coding: 0001168
Component: RDK 0453
Coding: 0100101
Coding: 0001168
