Electrical Gremlins - looking for help
axnels2
Denver
2009 jetta sportswagen
in the last couple of days my JSW started acting strange: lights coming on for no reason, doors wont open, key wont turn. I resorted to unplugging the battery and after that things appear to work better.
I cleared the codes but central convenience issues still happening. Is my CU going out? Expensive item to replace I hear....
Saturday,11,April,2015,12:44:10:53003
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 62 65 72
Mileage: 108600km/67480miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: 12H01--- Serial number: VWX7Z0I124C0GP
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 3FA3AAE56EB2B7E6A2D-806A
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1953
Revision: 04844002 Serial number: 00000811130854
Coding: 0000020
Shop #: WSC 00028 000 00000
VCID: D1871C5D4826B196C49-8084
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B600D492400FD880F06EA921E0042B000
VCID: 75CF08CDDC0E3DB6B81-8020
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JJ HW: 1K0 820 047 JJ
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 75CF08CD1C0E3DB6B81-8020
1 Fault Found:
01296 - Sensor for Vent Temperature; Center (G191)
007 - Short to Ground
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000009298417
Coding: 04898F2340041500070000001C000000000873075C000120000000000000
VCID: 3245F3D1ADE06A8E5D3-8067
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 050209 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 0K AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08L391
Coding: 0012363
VCID: 6DFF20AD745EF576401-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME41052F143
Subsystem 3 - Serial number: 6342MSME4330563EA
Subsystem 4 - Serial number: 6351HSME1B452579B
Subsystem 5 - Serial number: 6361HSME1B2E0871C
Subsystem 6 - Serial number: 63727SME1B600D5B7
Subsystem 7 - Serial number: 63827SME1B60146D3
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001034
VCID: 8225E311DDC09A0E0D3-80D7
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0005000 Serial number: VWX7Z0I124C0GP
Coding: 0007203
Shop #: WSC 20129 444 64522
VCID: 3957C4FD709699D69C9-806C
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 205
Mileage: 108424 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:39
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 205
Mileage: 108443 km
Time Indication: 0
Date: 2000.00.00
Time: 19:20:47
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 101208F2000424
Coding: ED807F07001002002002
VCID: 3753C2C546828FA66AD-8062
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2EGJ03
VCID: FDDF90EDA43EE5F6701-80A8
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2418
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000515189128
Coding: 0001205
VCID: 6FC33AA57E52076672D-803A
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 70 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C79EDA98FC43C7E17F-8079
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 DA HW: 1K0 959 433 DA
Component: KSG PQ35 RDK 052 0225
Revision: 00052000 Serial number: 00000000000000
Coding: 1390078852830C3E2904058FB0880F0488DC00
VCID: 72C533D16D602A8E9D3-8027
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00332 - Control Circuit for Tank Flap
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 21
Reset counter: 165
Mileage: 0 km
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08121601350503
Coding: 0001204
VCID: 70C139D9636C189E6B7-8025
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003721937
Coding: 0001168
VCID: 76CD0FC1010836AEB1B-8023
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0453
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003761699
Coding: 0001168
VCID: 77D302C506024FA6AAD-8022
End ---------------------------------------------------------------------
axnels2
Denver
I should have provided more details. A couple of days ago the remote would not unlock my doors. I had to use a key. Replaced a battery in the keyfob all seemed fine. Yesterday when I got into a car , headlights came on and the hazard blinkers when I tried to start the car. it started fine. This morning I could not unlock the car at all so I used the key to unlock my door. When I tried to start the car, the starter would turn the engine but it would not start. The lights and the radio came on too. I tried pulling the key out at that momement and it would not go back to the unlock position......
I ended up disconnecting the battery and after reconnecting all worked fine... I cleared the coded but the convenience module came back.
The car electrics have not been touched in 3 years. I have an after market radio thats been there about 3 years. A disabled fuel door that stopped working. I disconnected the fuel door lock motor. I noticed door locks sometimes make a grinding sounds but seem to work fine. Nothing else unusual.
One more thing I forgot to add: it also has aftermarket fog lights. I noticed that one has condensation in it.... Its not broken and works fine. The lights are about 3 years old.
Hyde7278
Central Mich
2001 Golf GL
Try disconnecting both battery cables and touch them together for about ten seconds. Then reconnect the cables and start the car and clear faults and then check to see if any come back. What your doing is a static discharge of the electrical system. I've seen it fix a lot of weird electrical issues.
Henrick
Ireland
Golf VI TDI, 77 kW (CAYC)
There are several faults about fuel tank control and driver's doors.
Have you checked the wiring harness inside the boot, driver's door for possible damage?
Things might be shortening there.
axnels2
Denver
the fuel tank I know about. I have disconnected that locking motor cause it got me stranded one time... The door, on the other hand, I investigated and did not find any broken wires. I will look again just to make sure I did not miss anything...
axnels2
Denver
After a few months and a couple of occurrences of my car "locking" itself up I found the source of all my issues... I had a loose wire on the fuse box in the engine bay, that would wreck havoc on my electronics and CAN-BUS. It got so bad that at times I could not even connect with VCDS. Thank you all that contributed to this thread.
meerschm
Fairfax county VA
Thanks for the update.
which wire was loose?
axnels2
Denver
if you are looking at the fusebox/breakout panel from the front of the car, it would be the 5th from the left.
meerschm
Fairfax county VA
attached to the bottom of an 80 amp fuse?
axnels2
Denver
My panel looks a a little different with no fuses/labels , but in your picture it would be an 80 amp. Perhaps due to date of manufacture been different. Mine was build in 02/09.
