Psilovybin
So, I have some battery drain. Worst offender is the radio. Turned the car completely off, key out and the Switched hot wire to the radio stays hot all the time. Went into VCDS and turned the radio off hoping that would solve the issue but still, the switched wire on the radio is hot. There are some other things that stay on while the car is supposed to be in sleep mode. I've got it down to .3amp with the radio fuse out. with radio fuse in, pulls about 1amp of current. Anything else I need to check. Is there anything in VCDS I can look at to discover what isn't going to sleep when it should?
