mattcoyote1042
showing code P068A: "power relay de-energized performance too early"
has anyone dealt with a similar issue? is it resolved by replacing this power relay?
is this the correct power relay: https://parts.vw.com/p/Volkswagen_2014_Jetta/Accessory-Power-Relay/52919700/5C0951253A.html
where is this located in the vehicle to replace it?
more details below, any help or advice received gratefully. thank you!
i got this car (now with 100k miles) few months ago. there had been a leak from the sunroof coming into the car, it hasn't done this since i've had it. one day i had a dead battery, i got a jump, had the battery tested and all seemed well. then it died again, so i got a new battery (optima yellow top). ever since it has had electrical issues with the sunroof and windows, as well as not starting reliably. it will take many tries to start. once, after sitting for 6 days, it wouldn't start at all. it ended up starting with a jump. i've noticed that if i try to start it and it doesn't start, if i let it sit for a few minutes it's more likely to start. i tested the voltage and it was below 11, still, eventually it started. when it's running the voltage was at around 13.8. even when i disconnect the battery while it sits it the problem persists. it didn't seem to take a charge—only showing 1 ohm and still had trouble starting.
