tadawson
7 hours? You can keep it! 250 miles on the Interstate system for me is closer to 3, and *zero* need to stop . . .
I just watched an online Tesla 3 where the guy did 250 miles in over 7 hours with two stops to recharge along the way
Model S went from 250 miles to 400 miles in like 5y, if the same % range boost comes in the next 5y could end up with a ~700 mile EV and I think that would relieve most people's range anxiety.. 600 miles is about the limit most people are willing to drive per day, 9-10h behind the wheel is enough for me and it would be full by the time I wake up.But if you can't drive 24 hours straight without stopping, I'm not interested. Just give me some of those NASA diapers and a bottle of amphetamines and it's road trip time!![]()
You know the saying, "If one is asking how much it is, one cannot afford it".I find it comical that Tesla still has no pricing or "starting at" on their website like literally ever other carmaker has.![]()
I totally agree with you. tried to make a joke...ticaf, the "call for pricing' game is a bit snooty for a car that is not an exotic. Audi has no problem listing starting prices on $80k+ cars.
Yes, typically the price of the product is generally proportional to its weight. Since LFP battery have more energy density than Lead batteries, they will tend to be cheaper eventually as the market adjusts to demand. Which is also why I believe it will be very difficult for BEV to reach 'purchase' price parity with ICE considering one need to mine an extra 1000lbs of expensive chemicals to build the BEV.Battery Prices are dropping dramatically, Commercial off the shelf drop in LFP is almost reaching parity with lead house banks.. I've got a 30lb LFP in my camper w/a 10 year warranty, that does the job of >300lbs of Deep Cycle lead batteries and with my large stand alone solar array it can fully recharge in ~2.5h of sunlight.. I paid a little more for the Lithium than I'd of for high end house batteries from a lead source, but with the weight savings and charge time accounted for its a better deal..
Not long ago it'd of cost 5-10x the cost to do this, and demand is still more than the supply.. dont seem unreasonable another decade down the line that high range packs are gonna be a fraction of what they are today.
Was just looking at eGolfs again. Can get a 2015 SEL premium for $11k and 47k miles on it. Or 2016 SE for $11.9K with 20K miles. SEL is 950 miles away and SE is 45 miles.
I was looking into solar again and found out I cannot install more than 105% capacity compared to expected usage. FPL does net metering so I figure one reason is they don't want people with huge credits, but unless the ever pay out I don't see the issue.
Also was told the regulatory reason why your solar shuts off during a power outage is because panels don't produce enough stable power on their own. You need storage or line power to fill in and stabilize the voltage. Installer said only real backup solution is Tesla and they are over priced/under perform. He's excited for a couple solutions coming soon from Generac and another company.
It was bigger issue when gas was costing me $150/mo and that's about what the note on a car would be. But my 1.8T JATCO just turned over 200k and original cylinder head and trans. Gotta be ready for when turbo/trans/etc. has enough and somehow takes the cylinder head with it. Keep putting off the rear main because of the JATCO packaging.
Jason
I'm using a BattleBorn, if I were to do it over again tho I'd probably get a Victron w/external BMS if I was going for an off the shelf, but now I'm comfortable enough w/my lithium knowledge and experience I'd likely just build my next one, just for direct access to each cell and BMS, and because raw prismatic cells are pretty cheap.. but I like the 10y warranty, and they already replaced it once because the first one I bought had developed a fault after a year so there is value in getting a commercial battery instead of DIY.Anyway, where did you get your LFP batteries ? I've been looking for some. even looked at used Tesla batteries on eBay. Prices are kind of reasonable, but I'm looking for rock bottom prices.
Also you want power or no power, not a little bit of power and then everyone has brownouts and damaged equipment. And on top of that there's no frequency to sync at without the grid.The real reason solar shuts off during a power failure (unless you've an islanded system) is because transformers work both ways and your solar still pushing power into the grid could KILL a lineman working on a repair some distance way...
Just did quick lookup for BattleBorn/Victron. Seems like price is still around $800/1kWh give or take. Tesla batteries are going for $200/kWh right now on eBay, but I have not had the time to figure out the BMS and stuff for them.I'm using a BattleBorn, if I were to do it over again tho I'd probably get a Victron w/external BMS if I was going for an off the shelf, but now I'm comfortable enough w/my lithium knowledge and experience I'd likely just build my next one, just for direct access to each cell and BMS, and because raw prismatic cells are pretty cheap.. but I like the 10y warranty, and they already replaced it once because the first one I bought had developed a fault after a year so there is value in getting a commercial battery instead of DIY.
Batteries are pretty simple things, far less complex and labor intensive than an ICE.. Most engines are still hand built now days with real human beings doing most of the work.. Batteries are fully automated, pour supplies in one end, batteries come out the other.. eventually its not gonna cost a whole lot more than the raw materials.
Extreme range numbers won't be what gets EVs to be mass-market. Normal (300 - 400 km) range combined with competitive pricing AND fast-chargers (150 kW minimum) at every motorway rest stop (plus countless other places) is what will do it.Model S went from 250 miles to 400 miles in like 5y, if the same % range boost comes in the next 5y could end up with a ~700 mile EV and I think that would relieve most people's range anxiety.. 600 miles is about the limit most people are willing to drive per day, 9-10h behind the wheel is enough for me and it would be full by the time I wake up.
A 700-1000 mile range EV might be attractive for the apartment dwellers too, If you got a short city commute that charge could be enough to get to work for a full month, so parking it at a 3rd party charging station for a few hours once a month or so dont seem that bad if your apartment wont provide methods for charging.
That's pretty amazing. Rumor is there's a 100 KWh Model 3 in the works.All that said, Model 3s have already crossed the county in under 50 hours.
EV drivers like to promote this concept, but it's flawed in my opinion, for many reasons. When Car & Driver ran a long-term test of a Tesla Model S, they noted that they ended buying food and drink where there were chargers, instead of choosing where they wanted to stop on road trips. When I traveled with my dog I'd stop at rest areas, not service areas, because he liked being walked in the quieter environment. And since it's pretty rare for me to have to refuel my Wagon during a day's drive (700+ mile range), we could stop anywhere we wanted.Most people stop for a coffee, washroom break, or a meal every few hours anyhow. (I certainly do.) Plug it in, have your break, unplug the now-fully-charged car, keep going.
People won't buy massive batteries so they only have to charge once a month. Yes, it's theoretically attractive for apartment dwellers but once a month is a fringe desire, sort of like the 600+ mile nonstop range. Too much battery tied up in theory rather than in actual use.
If you have a short city commute, e-bikes can be great options. Charge inside your house.
The people who want to pull two or maybe three 250 mile stints in a day, that's more mainstream for the distance crowd. And for that you need rapid charging and good distribution of charging facilities.
even if you bike every day like some of my co-workers who live within range to tolerate that nonsense all year long, they still got vehicles so they can travel.. If you just wanna go to a ski resort with a full day of traffic and heating needed between the trip up and down you'd probably be very interested in an extended range vehicle..People won't buy massive batteries so they only have to charge once a month. Yes, it's theoretically attractive for apartment dwellers but once a month is a fringe desire, sort of like the 600+ mile nonstop range. Too much battery tied up in theory rather than in actual use.
With ICE vehicles you can't just walk straight in and do that stuff; you need to pump/pay etc, then move the car, THEN you get time to go in and so forth. Traveling with a family a gas stop is a half hour thing no matter what. Plugging in and walking inside for 20~25 minutes (which can get you about 200 miles on the V3 supercharger depending on the SOC) is pretty much the same thing. Actually sit down with a sandwich, now you're getting 250+ miles.If they start releasing big number EV's even if most of it goes unused most of the time I think you'll find adoption picks up.. We're gonna get long range EV's far before we get battery chemistries in mass production that can fully charge in the time it takes me to take a **** and grab a coffee.
Sounds like a solution for the fringe cases, but people are doing trips with what's out there now.heck I don't mind if I gotta rent a small backpack trailer I can hot swap in 10mins if thats what it takes.. but thats gonna be long range design.. I think 700-1000 mile range is gonna be sweet spot where everyone stops caring about how fast it charges or if they can get a nightly charge.
Sorry, but I went back into the permitting and talked to my installer with 40+years. I brought this point up and was corrected by the authority issuing the permits and the installer, who has been doing this 40+ years, that the reason is voltage stabilization (brown outs) and frequency sync, NOT back feed into the grid.The real reason solar shuts off during a power failure (unless you've an islanded system) is because transformers work both ways and your solar still pushing power into the grid could KILL a lineman working on a repair some distance way...
