El Dobro
Photo Voltaic, solar panels.What's a PV system?
Photovoltaic solar power system.What's a PV system?
This is a function of the better environmental controls capable on a large stack, vs. a small tailpipe. Pure ammonia fed SCR's can knock NOx down to near zero at a natural gas power plant, while a CNG ICE vehicle's dry CAT can only do so much.One of the things about the Tessum graph that caught my attention was how much healthier it is to use natural gas to produce electricity for charging EV's as opposed to burning it directly in ICEV's.
There's definitely a synergy between EV's and clean, renewable power sources. People who buy EV's are far more likely to install PV systems at their homes, and vice versa.
I'm sure that's part of it. I think the greater efficiency of gas turbines and electric motors is another reason.This is a function of the better environmental controls capable on a large stack, vs. a small tailpipe. Pure ammonia fed SCR's can knock NOx down to near zero at a natural gas power plant, while a CNG ICE vehicle's dry CAT can only do so much.
What would be interesting to see is the ratio of single family homes versus multifamily homes in EV ownership. With all the condos going up around Charlotte, I assume that all would be equipped with EV charging stations.One of the things about the Tessum graph that caught my attention was how much healthier it is to use natural gas to produce electricity for charging EV's as opposed to burning it directly in ICEV's.
Photo-voltaic ie solar panelsWhat's a PV system?
Yeah... because it's instant and local... the ground beneath the turbine warms slightly because the air mixes. The effect goes away instantly too unlike the effect of using fossil fuels which lingers for centuries.It also says "...The Harvard researchers found that the warming effect of wind turbines in the continental U.S. was actually larger than the effect of reduced emissions for the first century of its operation...."
Yeah... but you're ignoring the other fundamentals. Like the fact Joule poured hundreds of MILLIONS into this then got sold for scrap. The entire sector was a bloodbath with nothing to show for it. The researchers were quoted as saying they weren't even close. If PV was still $10/w I would still be diligently working in the nuclear industry. It's now ~$0.60/w so I shifted into solar. Economics matters.I'm talking about the POTENTIAL of biofuel. Biofuels from wastes already pencil out cost-wise as I've highlighted, even without any tax incentives.
The only remotely expensive part of a BEV is the battery and full parity is expected by ~2025. In regards to the study there were several glaring problems;LCDs ranged from 26¢ per mile for conventional gasoline ICEVs to 38¢ per mile for long-range BEVs using electricity derived from solar energy….[/url]
True, but that would mean taking down all wind generators, or at least stop further deployment of wind generators. The question is, what is better for climate in the transportation sector, renewable electricity or biofuels?The effect goes away instantly too unlike the effect of using fossil fuels which lingers for centuries....
That may be true, but it was algae biofuel which is still not cost-competitive. Biofuels produced from waste oils and fats, forest and agriculture wastes, and MSW are more cost-competitive with fossil fuel than algae-based biofuels. Using Joule as a indication of biofuel viability is like using Solyndra as an indication of solar PV viability....Yeah... but you're ignoring the other fundamentals. Like the fact Joule poured hundreds of MILLIONS into this then got sold for scrap. The entire sector was a bloodbath with nothing to show for it. The researchers were quoted as saying they weren't even close. If PV was still $10/w I would still be diligently working in the nuclear industry. It's now ~$0.60/w so I shifted into solar. Economics matters....
Actually, I agree but what source of data should studies use if not EIA projections? You should contact the lead author if you have questions/problems with that study. It should be noted that one of the co-authors was from EPRI....In regards to the study there were several glaring problems...
Perhaps, but there are some signs further fall in battery prices may be coming to an end. …Prices for lithium used in the batteries that power anything from mobile phones to Teslas more than doubled to $21,000 a ton in the past two years…. and …Cobalt prices are surging as demand booms on lofty electric-vehicle production goals from automakers.… and ...while demand for nickel keeps increasing, half the world’s nickel supply is too low in quality to use for car batteries…....Wind and solar keep getting better at a remarkable rate. ~10 years ago my first PV system consisted of 200w panels I purchased for $1.64/w and an 8kW inverter that cost ~$3500 and weighed 140#. The most recent system I'm working on will use 360w panels costing $0.62/w and an 8kW inverter that costs $1400 and weighs ~57#. The retail cost of this system is $48k and it will generate ~35MWh/yr. Over the 25 year warrantied life that's ~800MWh. The Tesla Model 3 averages ~3.5miles/kWh so that's 2.8M miles of fuel for $48k or $0.017/mile ($0.012 after subsidies).
Xcel is constructing a wind farm north of where I live. They plan to sell energy into the grid at ~$0.023/kWh which would equate to $0.006/mile...
But it gets even better than that... if the bulk of charging occurs at the convenience of the grid operators the overall cost of charging could easily be negative.
Incredible analysis. If the electricity isn’t clean, it’s dirty. Have you looked at the grid generation mix lately? It is getting cleaner and cleaner every year, with some countries producing the majority of their power from renewable sources.The entire thought that an electric vehicle has no emissions is ridiculously false! Maybe it doesn't emit going down the road, however, the power is supplied from a coal powered plant and emitting 3 times the power needed to create the energy used.
Unless the energy source is renewable, it's dirty!
Sent from my Armor_2 using Tapatalk
https://content.sierraclub.org/evguide/myths-vs-realityThe entire thought that an electric vehicle has no emissions is ridiculously false! Maybe it doesn't emit going down the road, however, the power is supplied from a coal powered plant and emitting 3 times the power needed to create the energy used.
Except it wasn't just Joule. Like I said... the entire sector collapsed with almost nothing to show for the investment. Solar PV is ~70% cheaper than it was 10 years ago and costs are STILL falling; Had biofuels achieved a fraction of the success that solar and wind have enjoyed I'd still be driving my TDI and filling it up with B100 for <$1/gal... Alas it was not meant to be Conversely... had PV failed to yield results in the same way biofuels have I'd be embarrassed to support it much like I'm embarrassed by the nuclear industry I was employed by until recently...Using Joule as a indication of biofuel viability is like using Solyndra as an indication of solar PV viability.
That's precisely the question that needs to be answered... I've seen several studies that wind and solar are unquestionably a cleaner and more importantly CHEAPER source of energy vs biofuels. NONE that biofuels are a viable substitute for wind and solar.renewable electricity or biofuels?
Except America where it's getting dirtier! I have a degree in the sustainable technologies and PV is crap so far as alternative energy goes. There is so much more available that is better and cleaner!Incredible analysis. If the electricity isn’t clean, it’s dirty. Have you looked at the grid generation mix lately? It is getting cleaner and cleaner every year, with some countries producing the majority of their power from renewable sources.
All that's fine and dandy if you compare everything to carbon emissions and ignore the carbon created when the panels were created along with the materials used and the fact that is produced by coal, or nuclear power in the first place.Except it wasn't just Joule. Like I said... the entire sector collapsed with almost nothing to show for the investment. Solar PV is ~70% cheaper than it was 10 years ago and costs are STILL falling; Had biofuels achieved a fraction of the success that solar and wind have enjoyed I'd still be driving my TDI and filling it up with B100 for <$1/gal... Alas it was not meant to be Conversely... had PV failed to yield results in the same way biofuels have I'd be embarrassed to support it much like I'm embarrassed by the nuclear industry I was employed by until recently...
Just in the last 18 months the cost of building wind in NM has gone from ~$1.2/w to ~$1/w! Progress... wind and solar have it.
The problem with wind and solar of course is intermittency. We need TWh of batteries ready to absorb surplus energy... might as well use the bulk of that storage for transportation.
The expiration of EV tax credits will be offset by the plummeting cost of batteries. The only resource constraint is cobalt and most manufacturers are significantly reducing or eliminating that from their batteries.
In not wind and solar to reduce fossil fuel use... what? If we use wind and solar... what's a more cost effective buffer than EVs? Ignoring the fact that wind and solar is <1/5th the cost per mile vs biofuel... what's a better way to avoid wind and solar curtailment? Why throw away perfectly good clean and cheap energy when you can put it in your car?
The cheapest energy is the energy you don't use... second to that is clean energy which would have otherwise been wasted from curtailed wind or solar; THAT... is where EVs truly shine. In March alone CAISO curtailed 80GWh of energy... that's the equivalent of 7M gallons of biofuel... cheap and clean energy... we just need a fleet of cars able to take advantage of it.
Not ignored at all...All that's fine and dandy if you compare everything to carbon emissions and ignore the carbon created when the panels were created along with the materials used and the fact that is produced by coal, or nuclear power in the first place.
Someday... though I think CH4 is a better candidate than C12H24 and mostly for rocket fuel. Just no way around newtons 2nd lawAudi would have you do direct air capture of CO2, and use that energy to split water, and then combine the CO2 with the resulting hydrogen through a GTL process to make syncrude, and then refine that syncrude into syndiesel, to use the excess energy.
That's why Audi has a solid lineup of CH4-powered cars. (A3, A4 sedan/avant, A5 Sportback)though I think CH4 is a better candidate than C12H24 and mostly for rocket fuel. Just no way around newtons 2nd law
