sdeck
- Joined
- Aug 25, 2006
- Location
- Northern Colorado Front Range
- TDI
- 2003 Jetta, 253K, 01M, DLC520s, VNT-17(sold); 2014 Passat SE 6M, 61,000 miles (Feb 16 buyback date)
I started a thread about this a few weeks ago, but the title didn't really cover the underlying issue once it was figured out, so I thought I would start a new one to get feedback.
I noticed a few weeks ago that my wheel was about 10 degrees left of center when the car was going straight. I pulled the wheel and it was one tooth off, but in the wrong direction. i re-indexed it correctly, but that made it slightly worse.
I took it to a reputable alignment shop and the guy was perplexed. After setting the alignment (which didn't take much), the wheel was even further cockeyed and he couldn't straighten it out and it was now pulling to the right while the wheel was cocked left. So, he gave me my money back (reputable shop) and suspected something in the electronic steering. Driving home, the "Electronic Stability Control Error" message popped up and the ESC and tire sensor icons came on.
Day 2- took it to VW dealer. They diagnosed ($58) that the steering wheel was too far left and thats why the ESC error came up. They put it on the alignment rack and determined front right wheel was slightly out of alignment, causing the pull to the right. After fixing that ($100), the car drove straight but the wheel was still cocked so the tech pulled the wheel and rotated it to the straight position, but now it is no longer indexed correctly on the splined shaft. Car drives straight, wheel is straight, but now when I start with the wheel centered and straight, it turns 1.6 turns to the right and 1.4 to the left. Dealer says it is normal. I can't figure out what is going on. the only thing that makes any sense to me is that the "gear" on the end of the steering shaft has skipped some teeth on the steering "rack(?)". I don't really know how this system works. The car was in a pretty severe accident back in September (rear ended hard back right and hit from the back in the front right by same damn car) but I didn't notice anything odd about the steering after the repair. I don't know if these are related.
is the uneven steering rotation OK?
How does this new electric steering work? Where could it be messed up?
