Yes you can change it to use W-T-F. I have water temp limit for iq and to limit rpm when cold.At the moment, my car run on WTK input for EGT and it work fine. Because it's an EDC15 optional value, all other measures are maintained...
But WTK doesn't limit IQ, and that was the aim....OTF does...
Hi, Rob....First thanks a lot for all of this. I'm not too good with small electronics to build the converter. I wonder if we could use a EGT sensor that has 0-5v already?
http://www.ecuconnections.com/forum/viewtopic.php?f=6&t=13533&hilit=fuel+limit+temp&start=75
A bit down we find that there is an "alternate calculation" of OTF from ***, which I use for my limiter.
Yes W/T/F and WTK are different....Oh i see, Didn't realize there was a different one, I thought you put wtk because w/t/f gets blocked here, lol.
Is the converter going to be for sale? I would like to buy one and do this.
If i can't use the w tf for limiting when engine is cold, I guess limit by egt super low?
No, you keep your limit as it is (coolant), and you use WTK to get EGT, or OTF if you need an EGT limit....Sorry, I explained it wrong.
I already have limit fueling by coolant T.
I would like to add the EGT limiter, but would that remove the ability to limit by coolant, as there is one map??
