The probe can handle a bend radius of 3x the diameter (they are 3/16" diam.) with no problems (2.5x is possible but is pushing it). So 90° is no problem - but you have to keep the bend radius up to where you are not shorting the TC wires in the sheath out. The sheath is packed full of MgO powder as an insulator which can displace if you are too aggressive in bending. Depending on how thick you make your flange and the angle that you use for your TC probe side entry it could work well.shizzler said:Without going out to look at my engine, I might not have any idea what I'm talking about, but what about this idea: Instead of a block off plate, a through-bored flange with enough thickness to bring a probe in at an angle from the side, in order to capture the EGT temperature at the same location without blocking off / removing the EGR?
I'm guessing theres not enough flex in the EGR pipe to pull it out from the exhaust manifold far enough to get a flange of sufficient thickness to get the proper probe angle. What kind of bend can these probes tolerate? I know here at work (dyno lab) we bend ours a full 90 degrees sometimes, but then they are much more prone to failure...
Basically I like your product but want to keep my EGR intact.
That sounds like a failure. It is how mine finally failed. Shows a reasonable temperature then jumps to full scale. What is happening is that the weld between the two dissimilar metal wires is fractured but still touching. When the wires are touching it gives an apparently good reading. When heat is applied the wires separate and you get an open circuit.REDNECKDZL said:Mark, what are the symptoms of them dieing?
Mine has been acting weird the last couple tanks, not sure if it's a short or soemthing with the gauge
it seems to be reading lower then normal idling, and then acts as if it's shorted out, reads full egt sometimes
Not sure - that would depend on the function of the gauge.Nash_TDI said:Mine quite working a while ago. When I turn the car to accessory position the gauge jumps up then goes back to rest again.
Any ideas?
Shipped out on the way to church tonight (Christmas Eve).FJ40Jim said:My EGT probe died. 8^(
But I really want the EGT gage to work, so I just ordered another one.
Hey Chris -borachris said:Hi,
Could you give me a price shipped to the UK?
My Post code is TS23 1HN.
Thanks!
Cheers, PM on the waymycruiseagent said:Hey Chris -
It's been a while since I shipped one to the UK - I've done Spain recently and that was a $15 additional charge.
Please PM me your full address and I can plug it into the postal service website to be sure about the UK add on.
Thanks,
Mark
