1986.5supra_kid
EGT installed glowshift max tow egt review
Well since I have pp764 and a 1.5 stage tune the smoke has been heavy and 16lbs of boost. mpg has been in the 20's i dont see any fuel leaking so its got to be all that black smoke.
I couldnt afford a isspro and the auber instrument isnt a analog type of guage so i opted for a glowshift EGT
http://www.glowshiftdirect.com/MaxTow-1500-F-Pyrometer-Gauge.aspx
uses a 1/8th npt k probe and i drilled the manifold in the center as best i could between the turbo fasteners
installed the compression fitting
inserted the probe. i put it in far enough that i felt it would be in the stream on exhuast
Thoughts on the EGT kit.
It came with detailed instructions. 9ft of probe wire is plenty. i bet you could wire it to the trunk if you wanted haha. the fittings where pretty nice. the probe was nicely made. the wiring was 22 or 24 gauge for running and illuminating it. the motion of the gauge seems kinda slow when in operation. ex. i can be at 380* and mat the skinny pedal with a great black cloud and it will climb to 1250* then i drop to neutral and it will slowly come back down. it will come down faster if left in gear but i figured it would act more like the Tach or the Boost gauge
A/c on at idle 350*-440* depends on day or night
my normal granny mode driving is 500*-650*
my accelerating with traffic is 700*-900*
hammering down is 1200*-1450*
fuel economy sucks my fill up was 200 miles at half a tank. used 9 gallons
Hammer mod may need done.
i may see if the VDO egt works with the k probe. and compare.
overall i paid $55 for it and it does tell me that its making heat the response will need compared though
