honda_vtec2
I'm loosing boost through my egr weep hole. There seems to be more oil pouring out of there these days. Is it a bad idea to seal that hole up with high temp silicone?. Why is that weep hole needed?.
TIA
TIA
Since i've posted, i came across a thread somewhere on the site of a user tapping the hole and running a fitting/hose back to the ccv assembly. I'm going to look at that and see if i can run something similiar.The weep hole is needed to equalize pressure on the back side of the EGR diaphragm. For a properly operating EGR the weep hole is needed. Folks with the oil problem as you describe drill and thread the hole and install a fitting so that they can attach a tube and run the oil either to the ground or to a collection container attached somewhere in the engine bay.
Could you explain your loss of boost and the amount of oil coming from the EGR weep hole? I'm not a guru but it sounds like you may have other reasons for your boost loss.
Thanks for the tips. I'll take a closer look at that weep hole.I've only glanced at it. I think there might be a bearing or something in there. I'm guessing i might have to attach a fitting in that weep hole.I used another, smaller piece of tubing. The translucent tube visible has a slightly smaller ID than OD of the 'coupling' tube. That smaller tube has an OD just slightly larger than the weep hole ID. The puck has a hole added just smaller than the translucent tube's OD. It's all press fit.
I don't doubt that there is smoke / oil mist coming out of your weep port. I don't believe that there is enough loss (guess...maybe 10 cu.in./min?) relative to the air volume passing through the engine (900 liters/min at 900 rpm) for any real measurable loss of intake pressure.
Thanks again Mr. Lugnut. I'm going to swap out my injectors and that n75 and do some more logs/tests soon. I'm thinking i might have damaged my injector nozzles when i was cleaning/rebuilding my cyl head. I left the injectors in the head while i did that job, maybe the nozzle got slightly clogged...I was careful, but maybe some soot or sand got into a cavity...A failing N75 would result in a surge (power-not so much power-power-not so much power) under higher load, like accelerating in 5th from 80 kph.
A more rapid 'stutter', especially at light load in the lower gears (just off idle, 2nd, 3rd) is more likely an imbalance in the injector spray pattern, or a sticky injector pintle.
At idle (and just over) the engine computer individually controls the amount of fuel delivered to each injector to smooth out the idle. A weak cylinder gets more fuel to compensate.
Once the rpm is above that control range, the fuel delivered is equal. Not that the fuel injected is by default equal, or that the spray pattern is equal. A sticky injector might not be delivering the full charge of fuel supplied and this 'weak' cylinder exhibits itself as a 'misfire' symptom.
