champagnecharly
Hi, I'm new on here.. recently purchased a 1.9 sharan and its sadly not without issues. I hope somebody can shed some light.
I have tried to and rule out fault MAF as I was getting readings in excess pf 200mg or 50% above specified. When i drove with maf diconnected it ran like of bag of nails. No power and i could barely get past 3000rpm. or 60mph
I also tried the blanking of EGR vacuum pipe but that resulted in stalling.
The EGR was absolutely caked even the entrance to the cooling pipe was almost entirely blocked when i cleaned.
Since cleaning the egr valve i am getting valve either at 84% or 4.4$ under throttle it does fluctuate a little in between but only for short bursts and it will be back at 84%
Could anybody please offer some suggestions? intake Pressure actual 1017.9 compared to 1020mbar without engine running and 1043-1050 at idle. Pressure is constant other than when throttle is pressed..
If somebody could offer an theory on what i happening here id really appreciate it?
Also note.. emissions pre egr clean were very high. Not got it tested sine/yet.
