PimpJuice216
I have a 1998 mk3 Jetta TDI and I want to do an EGR delete but am not at all sure on which kit is worth my money and will last. Does anyone have any suggestions?
the n75 has NOTHING to do with the EGR. do not disconnect any of that. you want to delete the entire EGR controller by plugging the line from the vacuum pump to it! not the n75- Small vacuum hose cap for the N75 solenoid (since it no longer needs to attach to the EGR Valve)
Correct! My mistake. It has been a while since I tinkered with either of those. For some reason, I thought they were integrated into one unit. They do look somewhat physically similar. The vacuum control valve is separate from the N75. But yes, you will need to cap off that port on the vacuum controller if you decide to delete the EGR itself.the n75 has NOTHING to do with the EGR. do not disconnect any of that. you want to delete the entire EGR controller by plugging the line from the vacuum pump to it! not the n75
