Caidenp9
Hey yall I’m looking into getting a 05 Passat TDI It’s got the balance shaft delete and a new oil pump also it got a stick swap with a O1E but he’s claiming it’s got a bad head gasket. With everything I’ve read it looks like it’s mostly a EGR Cooler problem, I’ve also read that it’s almost better to just get the delete kit than replace it. What’s the major pros and cons that anyone on here knows, and if any one has a strong enough opinion on it which way do you lean.
