Yea, but if you read what's actually covered under that 5/60 you'll notice they leave out the HPFP and even the turbo, by golly!
Many here have corresponded with VW CC and were emailed in return that the HPFP is covered however, that may or may not be enough to actually get it covered unless you litigated them till the cows come home.
The HPFP sees no engine oil for lubrication and the turbo receives oil via line supply and therefore they can most likely weasel out of that too under the internally lubricated only clause. Later!
