EDC 17 /MED 17 Immobilizer OFF service - Immo Data Programing
jetta 97
Dallas (McKinney) ,TX ,USA
Golf 2004 & Jatta MK5 2006
EDC 17 /MED 17 Immobilizer OFF/DELETE service - Immo Data Programing.
Immobilizer OFF or programing USED EDC 17 /MED 17 ECU.
-EDC 17 ECU is form TDI 2009 and up
-MED 17 is form Gas powered cars 2009 and up.
This is also possible for anyone who can read ECU Internal Flash +Eerpom.
Means if you are able to read
Internal Flash +Eerpom, you do not need to send me ECU, all you need to send me files and I can do immobilizer Off or transfer immobilizer data from one ECU to Other and make it plug and play.
Also Available
Immobilizer OFF and programing USED ECU in those :
-EDC 15 ( TDI engine 2000-2005)
-EDC 16 (TDI engine 2004 and Up)
-MED 9.1 ( Gas/Petrol engine 2.0T 2005 and up )
-ME 7.1.1 (Gas engine 2000
and up)
-ME 7.5
(Gas engine 2000 and up)
-ME 5.9 ( Gas engine 2.0 none turbo 2000-2001)
For Price list you can visit website :
https://www.advancedcarelectronics.com/
If you have Any questions please send me private message or email:
info@advancedcarelectronics.com
marinmm2001@gmail.com
jetta 97
Form May 26 2015 to July 6 2015 ,
anyone how needs this service it will receive $100 off discount.
When you contact me just send me this link .
jetta 97
September month discount.
$50 off on any Immobilizer jobs when ECU is shipped to me.
Dorkage
Thunder Bay, ON, Canada
2003 Wagon TDI, 2004 Golf R32
I have a MED9.1 that I need IMMO off on. Can you do that? Is there anything I can use to easily read the EEPROM (ideally over OBD) to send to you?
coolvdub
SoCal
2001 Jetta TDI/2013 JSW
Marin is the man. He offers fast turnaround and really good prices. Don't hesitate to use him for your cluster programming needs. Corrected the mileage for me when I couldn't.
jetta 97
We all know what is going on with all Common Rail 2009 and up cars and probably they will have flash for ECU.
If you want to keep it original ECU, I can transfer data to other used ECU,
If Anyone need this please be free to contact me.
Bambaataa
KW, On
06 Jetta BRM 6MT; '15 Golf Sportwagen TDI GSW
Do you have a public listing of your price(s) somewhere?
Filmshoot
NORCAL
1.9TDI AFN
Hi can u build me a wire harness so I can upgrade to edc15 from msa 15?
I have an afn motor in my 97 eurovan.
I want the ability to flash from obd port into the 32bit edu
I hate having to make and swap chips in my old ecu
Inscribed with just two thumbs...
Heavy_D
Detroit
2004 Jetta, 2014 Passat
Highly recommended!
Good evening all,
I highly recommend Marin for any ECM work you need to have done. He provides excellent support and customer service. I can't say enough positive things about my experience. I just wish he was closer, so I could use his mechanic services!
I sent in a junkyard ECM for my 2014 Passat TDI to have the immobilizer disabled. Unfortunately, this was not possible, so Marin cloned my ECM instead. Yes, we had to ship the ECMs back and forth a couple times due to the stubborn IMMO, but it was well worth it. It worked like a charm!
I now have a backup ECM in case anything bad happens to the ECM or its programming...
Thanks!
Heavy_D
02Jetta
WV
02 JETTA
No one should feel any hesitation to have work done by Jetta ,97!
MARIN did a great job on my immob probem and swapped out my instrument cluster that went bad.
He did everything just as he promised. THANK YOU!
jetta 97
I am glad I was able to fix everything .
Just to mention that was 2011 Jetta Wagon TDI.
Thank you for trusting me on this.
Strider17
Hamilton, Ontario, Canada
Beetle(sold) MK4 Golf TDI(sold) Mk4 Jetta TDI(parted out) MK4 Golf GTI w/ALH swap (built then parted out) 2015 Passat TDI Highline (current)
Jetta_97 has helped me with my 2009 2.5L gas to 2.0 CR TDI swap on my 2009 jetta wagon
he knew exactly what he was doing and got it done fast and right the first time around....flawless!!
he was able to take my full FIS cluster from the 2.5L, take my donor half fis cluster from the 2.0 CR TDI and take all the immobilizer and programming and combine it into a FULL FIS diesel cluster i gave him. Along with programming the keys/ECU.
all i did was plugged it in and worked.
update: few months later!
everything still works exactly how it should. no codes and no problems!
I highly recommend his work to everyone and i will definitely be a returning customer of his with my other diesel swaps
2005vwmk5tdi
Usa
Brm tdi
Hi i am interested in immo off i have 2005.5 jetta tdi brm new body style and 2009 vw jetta 2.5
kbrenny
Sachse, Texas
2002 Jetta wagon TDI
I have dealt with Marin many times over the years. Just wanted to let everyone looking here to know he is a great guy and probably one of the best people on this forum to deal with.
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2003; 2016 A3 e-tron
What he said. Marin is a great resource, super-generous with his knowledge, and has always been willing to help and answer my questions.
