P2B
My 1Z A3 has PP520s but is otherwise stock. I wanted to increase boost to match the increased fueling, but chipping isn't in the budget right now so I decided to go with a bleed.
Just to be different, and because bleed valves are crude IMHO, I decided to do the bleed electrically, by installing a diode between the MAP sensor output and the ECU. The forward drop across a diode is 0.7V, which corresponds to 5 PSI in the transfer function for the A3 MAP sensor.
In other words, I modified my ECU such that the MAP sensor always reports 5 PSI less than actual to the ECU - so I expected maximum boost to increase by 5 PSI.
It doesn't work
Maximum boost (as reported by my LED boost gauge, which has it's own MAP sensor) is unchanged - still the stock 12.5 PSI.
Maximum requested boost (as reported by VAG-COM) is unchanged - still the stock 12.5 PSI, as expected.
Maximum actual boost (as reported by VAG-COM) has dropped from 12.5 PSI to 7.5 PSI - but at least it's not throwing any codes!
Obviously performance is unchanged, because I'm still running stock boost.
I assumed the ECU would simply control maximum boost to 12.5 PSI above nominal atmospheric pressure, but it seems be more sophisticated than that - it appears to read MAP output at idle, and use that as atmospheric pressure.
I now assume that, if I decide to pursue the idea, I'll have to design a circuit that only modifies the MAP output to the ECU when actual manifold pressure is more than 5 PSI above actual atmospheric pressure.
Anyone know more about this than I've learned through the experiment described above?
Simon
It doesn't work
Simon
