ECS steel skid plate question
Cosmo's UNA
VIRGINIA
2003 Jetta TDI Wagon
Does anyone know if Diesel Geek Full Metal Jacket Side Skirt Set works with my steel skid plate? ALH TDI Jetta wagon For those of you that have this skid plate, did you run into any fitment problems? I have close interference with my lower radiator hose. Thanks folks!
Cosmo's UNA
VIRGINIA
That's good advice. I'm working (potentially, haven't bought the side skirts yet) with parts from two different companies, ECS and Dieselgeek, IDK if they are speaking the same language, are compatible.
454k30
Long Beach, CA
2002 Jetta
For what it is worth, to use the panzer plate from DG we have to modify the plastic side skirts to fit that plate. In my imagination, the steel plate is likely closer to the plastic cover than it is the DG offering. So, with that in mind, the DG side skirts are likely not going to fit an OEM plate. But that's all assumptions.
Zak99b5
Albany NY
2003 Jetta TDI
I’ve looked at that OEM skid plate. I was wondering if one couldn’t just fasten the oe plastic side skirts to it so that when you pull the skid plate, it all comes out together. You’d probably have to cut the very tops off.
Cosmo's UNA
VIRGINIA
That's a good idea. I think cutting plastic to fit is the way to go. I just want to protect the passenger side with the belts exposed from anything the road/wheel can kick up, most of it anyway.
turbocharged798
Ellenville, NY
The ECS steel skidplate is junk IMO. Not impressed at all. Thin steel, alignment isn't great, and trying to make it work with the OE side covers is a major pain.
I really like Evolution import skidplate from Cascade German. Great price and great product. Easy to make it work with OEM side covers with a bit of trimming in the front part.
Cosmo's UNA
VIRGINIA
Cut original side skirts to fit, very easy. I couldn't pass on the steel ECS pan, it was new, never installed and I bought it from a young man with a beautiful family including 5 young children.
Bob S.
Central MD.
A B4V, some ALHs & BRMs
Cosmo's; I have a one of the VW Mk IV platform steel skid plates that I will likely never use. New, out of box. Located Maryland. PM me if you have interest.
benmarks
Portland, OR
2004 Jetta GLS Sedan Platinum Gray
When I saw this thread earlier, I noted the one on ECS was the OEM one, but I decided not to reply. Technically, there were two versions, a 1.35mm version and a 2.8mm version. I have the the thicker one so I didn't want to comment on the quality of the one ECS sells because it is the thinner one (if their OEM part number is correct):
1J0698930 - 1.35mm
1J0698931 - 2.8mm
With that said, my thicker one is awesome and has saved me a few times after running over some pretty gnarly things on the road. My only issue is that my TDI guru complains when he has to remove it due to the weight ;) And, it required very minimal modification to the existing side skirts to fit.
