tdiblair
- Joined
- May 16, 2005
- Location
- CT Yankee
- TDI
- Passat 2005 silver Passat Sedan & 2005 Wagon Stone Henge Gray
Ok, just pulled the wiper arms off with a mini puller.
Next on the skinny black plastic shroud immenidately under the windshield wiper arms ( not the big two part battery shroud which I already pulled off ) - I've found 2 clips on the smaller shroud directly under the windshield and wiper arm which I can't remove, yet. One holding the middle of the shroud the other over by the driver's side removed - thinking their should be a 3rd pull off retaining clip over by the passanger side near the cabin air filter but not finding one. Didn't see any mention of these retaining clips on the instructions on the web site.
Next the instructions show a pop out circular plug next to the drivers wiper arm and 4 screws you are suppose to removed. I'm confused on that "4 screws you can see" - my guess is that little plug I just popped out can only access (1) screw.
I'm too stupid to figure out how to get this last shrould off so I can access the 219 Relay to the ECM which is prone to fail - any help on where these 4 screws are that I can't find and why am I not finding a 3rd slide of retaining clip over by the passenger side? Where have I failed?
The read on line instructions and still having issues.
I don't know where these 4 screws are....and thinking there has to be a 3rd slide off retainging clip holding the passenger side of that shroud and not finding it either. Maybe it's a senior moment I'm having.
Blair
Blair
