+1...it doesn't get hot, it blows out warmer air quickly. If you put your hand down by the air outlet right after the car is started, you'll feel warmer air coming out.
VAG-2009 Golf, Vag-com say aux heater not present. Is it possible the Jetta has it but not the Golf???
On what Car?Any ideas about how to check if this thingie is actually working?
I think you're right.isn't the "aux heater" controller for an installed Webasto?
It certainly is possible but a lot of other thing might draw power including a bad diode in the alternator or the electric steering.Sorry to dig this one up, but is it possible for this heater to draw 30 AMPS with the key out of ignition ? This is what mine is doing, killing the battery in about 2 hrs. It's almost like a short, but maybe that's how it works. (causing a short) ?????? correct me if I'm wrong.
Why don't you just remove the fuse and check with a voltmeter in ten minutes?
To see if it is drawing power with the key out.
Not sure were the controller is but I suspect it is part of the Z-35 heating element.Yeah, that's what I thought Ol'Rattler. In the Bentley diagrams I didn't see any switches or relays between that fuse and the Z35 Aux Heater but wasn't sure if I was reading the EWD correct or not.
I'm meeting up with another forum member that's 15 miles away from where I am to get the VCDS on it. In the meantime, the battery holds the charge at least 2 days with the fuse link disconnected.
Do you know if the J-604 controller is integrated with the element as one piece or is it replaceable ? Thanks .
North American MKV Jettas DO NOT COME WITH AN AUX HEATER.It certainly is possible but a lot of other thing might draw power including a bad diode in the alternator or the electric steering.
Any thing that draws that much would certainly spark when the power is disconnected.
From there, disconnect the large wires, one at a time, that come off of the under hood fuse box. If you get a fair sized spark from any of those, note which wire it is.
- Start by disconnecting the + battery connection and if you get a fair sized spark, reconnect it.
- Disconnect the + wire to the alternator, look for a spark and reconnect it.
- Disconnect the + starter wire look for a spark and reconnect it.
Report back with your findings and be extremely careful not to ground the wrenches you use or the wires you disconnect because all of the connections that you are disconnecting for trouble shooting purposes have battery voltage on them pretty much at all times.
Alternately, and probably safer, you could disconnect the battery + terminal prior to each time you disconnect something, insulate what you just disconnected with tape and reconnect the battery + after each item. At some point, the spark at the Battery plus will be a lot less indicating which item has the excessive draw.
Hope all that makes sense................
Very strange. Mine did. Had it out today. ???????????????North American MKV Jettas DO NOT COME WITH AN AUX HEATER.
End of Line.
The '09 Jetta is an MkV and indeed has the aux heater.North American MKV Jettas DO NOT COME WITH AN AUX HEATER.
End of Line.
Bull loney. I bought my 09 JSW in Miami and the aux heater is certainly there and works fine.North American MKV Jettas DO NOT COME WITH AN AUX HEATER.
End of Line.
