Jamie93
Hi,
I have an EA288 TDI 2.0 184ps which suffers with extended cranking during the first start of the day. The duration of the crank seems to vary and some days is instant, however, on other days it can take up to 8-10 seconds before it fires up. The car has never not fired up, but the crank is sometimes at a constant speed, but other times seems as if it is stuttering during start up. On some of the longer crank times, a Start Stop Error message comes up on the dashboard and the start stop system is unavailable until the ignition is cycled again. There is no EML on and the car runs fine once started. Any starts once warm or following the initial start is fine.
Below is the VCDS scan for my engine module. There appears to be errors stored for the Camshaft Position Sensor, as well as the camshaft positioner. Is the camshaft positioner referring the VVT actuator on this engine?
Has anyone seen this before or has any idea what may be the cause of this? The Camshaft Positioner or the Camshaft Position Sensor? I am surprised there is no EML?
Thanks,
Monday,09,November,2020,15:24:00:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 148389 Repair Order:
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 021 EP HW: 04L 907 309 A
Component and/or Version: R4 2,0L EDC H22 8359
Software Coding: 01190032034505082000
Work Shop Code: WSC 34526 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021EP 002011 (VW37)
ROD: EV_ECM20TDI01104L906021AE.rod
VCID: 77FA309ECE56043E3A-8022
5 Faults Found
8195 - NOx Catalyst/Trap Bank 1
P2000 00 [096] - Efficiency Below Threshold
Intermittent - Not Confirmed - Tested Since Memory Clear
19232 - Camshaft Positioner (Bank 1 Intake)
P000A 00 [096] - Slow Response
Freeze Frame
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 237234 km
Date: 2020.10.30
Time: 17:19:45
Engine speed: 768.50 /min
Normed load value: 31.4 %
Vehicle speed: 0 km/h
Coolant temperature: 77 °C
Intake air temperature: 57 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.360 V
Unlearning counter according OBD: 27
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
19233 - Bank 1: Camshaft A (Intake)
P0011 00 [096] - Retard Setpoint not Reached (Over-Advanced)
Freeze Frame
Fault Priority: 2
Fault Frequency: 3
Mileage: 237370 km
Date: 2020.10.31
Time: 16:02:31
Normed load value: 25.9 %
Coolant temperature: 91 °C
Intake air temperature: 71 °C
Ambient air pressure: 1000 mbar
Unlearning counter according OBD: 29
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
4113 - Camshaft Position Sensor (G40)
P0341 00 [096] - Implausible Signal
Readiness: 0 0 0 0 0
Thanks,
www.Ross-Tech.com
VIN: License Plate:
5 Faults Found
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Mileage: 237234 km
Date: 2020.10.30
Time: 17:19:45
Freeze Frame
Fault Priority: 2
Fault Frequency: 3
Mileage: 237370 km
Date: 2020.10.31
Time: 16:02:31
U0164 00 [032] - -
