EA288 - A diesel way forward?
Sunnyb
MI
2015 GSW
I'm hoping I don't have to take it in for service under the warranty. Heck I'm leery about the first oil change on them, they will probably reflash if its out. I only have 5k on it now.
SpecialTest
USA
'15 GSW TDI S
Funny you say that, I was too, and I just picked my car up from the dealer for the 10k service, plus an AC issue.
Now I know it's not fair to VW, but the gas mileage on my daily commute was lower this morning. I'm normally around 49~52mpg via the center console for the "since start" mpg, but this morning I only got to 46 mpg. It's not entirely unusual, but it's got me thinking "Did they flash it already!?!"
I'll have to report back once I get a lot more miles on the car after this service, but it's most likely just me seeing something that doesn't exist.
sapgar
Colorado
2015 GSW TDI 6MT
First of all, the MFI can be off by 5 to 10% at times. Second, when the temp drops, you run your AC or run the seat heaters, I've found the mpgs to drop noticeably. There are so many factors that play into it. 49 to 52 mpgs is performance under ideal conditions.
One other note. My MFI had a really high average since start and per refuel since I purchased. Then I had a sub woofer installed where they disconnected the battery and the MFI kind of rebooted. Now my MFI readings are closer to hand calc'd (lower). I'm not sure the software to flash is available yet. I've been in close communication with my VW service manager, and they don't have anything yet.
skramer
Viera, FL
2015 GSW SE 6MT
Didn't we already have a software update that was available for the ea288? I remember thinking on my 10k service the car would get a software update. This is all before the latest/possible ECU update or w/e route they go for the ea288.
andyrooski17
Newton, MA
2015 Golf TDI SE DSG
I just had 20k service, and there was the RVU 2309 ECM flash (available since May 2015, I think). Not a lot has been said about it, but what I've found on the forums speculate it has something to do with ash loading. FWIW, my service manager said it had something to do with a CEL that was coming on for certain cars.
I was assured it had nothing to do with this recent emissions business, and so far i've seen no hit in FE, except for the hit because it's been cold.
J.R.
Vancouver
2017 Sportwagon TDI?
VW is going to officially announce what the fixes are for each model/MY on Wednesday - the deadline given by Germany.
Almost everything you read is speculative until then...although I'm hopeful the 15/16's are unaffected.
Remember...those fixes will be for EURO CARS....different emissions standards than the US/CANADA....So I caution you we might be able to infer the US fix, but with more stringent requirements, it may not mirrior the German fix...
I also hope the new motor will be unaffected, except for a programming change to ensure no "banned" or illegal software.....
Yeah, I assume the Euro fixes will give us a better idea but aren't necessarily going to translate EXACTLY to N.A.
sapgar
Colorado
2015 GSW TDI 6MT
Very true. I've been doing research on SCR in general, and I believe the EA288 will have a much better chance at minimizing impact based on the application of SCR and the VW design with the EA288 (exhaust recirc, etc). It's just that I/we don't know what it takes to meet CARB's standards. The delay for us is probably to see what the performance impacts are to the EA288. They may try a pass with just the defeat device removed and then have to refine software code. This would be my guess as to why the absolute silence from them. They probably test, and then have to tweak and then test and then have to tweak and get the EPA to buy in.
Then the question is if the EA189 can be brought into compliance with CARB standards and what the impacts are to 1) performance, and 2) emissions hardware durability. Remember that the Passat has SCR but with the EA189. For example, I had a 189 in my JSW, and that sucker regen'd a lot, and I don't do much stop and go. My 288 now regens very rarely. If the emissions goes to "always on", what does that do to everything? VW is in a really bad spot with the US market, because it may take quite some time to develop a technical solution for the 189 engine. If the refit and emissions warranty risks are high enough, VW may just decide to buy the affected cars back and sell elsewhere or negotiate fines with the EPA and get a pass on the emissions since they're not selling those engines new in the US any more. Then they'd just settle with owners on some form of compensation.
I think a lot will depend on how clean the EA288 actually is vs. US standards. If clean, then why not release the 2016s and 2015s and have VW just pay a huge fine and make good with EA189 owners? Then the question is if VW can keep up with more stringent NOx standards coming in a couple years or just exits diesel in the US and brings over more of their Blue Motion gas technology.
LongEz
Texas
None yet
http://www.wsj.com/articles/volkswa...o-certify-2016-model-year-vehicles-1444243809
This link is from the "monster thread", but it is probably worth including here.
I am especially concerned because I have a deposit and VIN on one of the first 2016s due in the US, and it's been in Houtson for a long time (and will be for longer so it seems).
I can't imagine the Gulf air is good on a vehicle that is just sitting for months on end. Any thoughts or comments? I had hoped the urea + a simple ecu tweak would get the job done. Now I fear it may never happen.
Cheers?
LongEz
Caseyb476
CO
2015 Golf SE 6spd man
Cheers?
LongEz
Get your deposit back. I'm not saying it'll never happen, but it may be a while, and that's not your job to give a free loan to the dealer.
sapgar
Colorado
2015 GSW TDI 6MT
Cheers?
LongEz
To us it's probably simple, but they need to re-write the software and get buy in first. Probably will take a few months.
pandagolf
CA
2016 GSW TDI SEL ordered
Cheers?
LongEz
I'm in the exact same boat - have a deposit on a 2016 GSW TDI SEL (since June). This news pretty much seals the deal for me, unfortunately. I can't wait much longer for my car to arrive...
It's either GTI or V60 for me...
sapgar
Colorado
2015 GSW TDI 6MT
Both seem like good choices.
Cutandthrust
Nor Cal
'15 GSW, SE, DSG
I really really like the V60 (wish they had a diesel option) and think that its a fantastic choice. But I fear worse than this VW scandal, that Volvo will exit the US unexpectedly at some point ala SAAB, in lieu of stagnant sales. Think our TDI re-sale blows now. Imagine owning a couple year old V60 from a defunct company.
I actually like the V60 looks the best, but the space/ interior isn't as practical as the GSW, due to the sloping rear roof and back glass.
panda
Chichester, NH
2002 Jetta, 2015 Golf Sportwagen, 2005 Jeep Liberty CRD
The 2016's not coming to the US doesn't seem to bode well for the EA288 surviving with only a minor software tweak. When I bought my ALH in '02 those cars had already been on the market for a few years and there was a sizable amount of mechanical knowledge available on this forum. I worry that the EA288 will be an orphan design will little "user" knowledge available. The situation may become a lot like the '05 Jeep CRD sitting in my driveway. Dealer service is a last resort for the CRD and a constant fear. The parts are expensive parts if even available. The good news is it's a diesel and if taken care of will likely go the distance. I hope the same is true of the EA288. More patience is called for I guess.
I don't think we know yet what VW is up to with the withdrawn EPA application. Could be they're going to do something different like having the cars perform over-the-road testing before applying for certification. No one at VW has said no 2016 4-cylinder VWs that I've seen. Just journalists speculating.
The hardware setup of the EA288 is very similar to other cars that have met emissions standards.
Caseyb476
CO
This is from Michael Horn's statement to congress. It reads to me like they rescinded the original application, and are working on a new certification, NOT cancelling the 2016.
"In Volkswagen’s recent ongoing discussions with the regulators, we described to the EPA and CARB that our emissions control strategy also included a software feature that should be disclosed to and approved by them as an auxiliary emissions control device (“AECD”) in connection with the certification process. As a result, we have withdrawn the application for certification of our model year 2016 vehicles. We are working with the agencies to continue
sapgar
Colorado
2015 GSW TDI 6MT
Here's a good write up:
http://www.greencarreports.com/news...passat-golf-beetle-tdi-models-may-be-modified
pandagolf
CA
I think Volvo following Saab is a stretch.
Latest Volvo sales figures
The V60 is definitely smaller than the GSW, but something I can look past if I end up with an R-Design...
waspie
ne ohio
05.5 pkg2!
same boat as some of the others. money down on a car. car produced on 9/28 with a VIN. assuming its made port by now. I like the GTI but i drive close to 20k a year just on my car.... but there is 2k off on GTIs right now
and then supposedly the 2016s will be certified...but when? Will there be incentives?
This whole thing pisses me off. Not about the emissions, i'm whatever about that. i just want my freaking car.
TurnOne
Cincinnati, OH
2015 Golf SEL TDI 6MT
I think they will be offering more than the current $2000 off. I want a 2016 Golf TDI SEL with both lighting and drivers packages. We shall see what happens over he next couple months.
J.R.
Vancouver
That seems pretty logical.
Be interesting to find out the effects of the flash. Is it just to remove the offending code? Use more DEF? Will it alter MPG/performance at all?
Then there's the question of WHEN the 2016's will be certified.
Still more questions than answers...
A delay in the 2016's could bode well for me though :D
Springfield, VA
In today's Congressional hearing, Michael Horn indicated that VW will reapply for certification on the 2016s (after removing the cheat) and he expects them to be on the market in early 2016.
Sunnyb
MI
2015 GSW
If that is all they do, alot of 2015 owners will be happy.
andyrooski17
Newton, MA
I just watched that video as well. Interesting, although It wasn't entirely convincing they got the car in cheat mode. They also didn't test city fuel economy. I do applaud them for attempting to put numbers to the problem, rather than just speculate wildly.
Either way, based on this and all the latest info about the EA288 engines, it seems increasingly likely that EA288 models won't be affected too badly. Especially if VW can come up with a better solution than just switching on "cheat mode" as it is currently configured.
Looking forward to seeing CR test the fixes as they roll out
Zut Alors!
New Iberia, LA, USA
Consumer Reports did a test and found the cheat is worth 3mpg on 2015. More on the 2009-14.
It wasn't "cheat" mode. From what's been pieced together through reports, congressional testimony, and posts here and there on this forum, the ECU settings in question rely on far more complicated inputs from the car before engaging in a cleaner combustion than Consumer Reports did in their own investigation. As a result, it was only marginally more scientific than that dumb TFLCars video that came out a week previously.
dingdong
alexandria, va
09 JSW DSG, 2015 GSW DSG
I'm really anxious to get any info on the EA288. I bought my 15 GSW in June. I also have an 09 JSW with 100K miles on it.
sapgar
Colorado
2015 GSW TDI 6MT
If they can't tune the EA288 to meet emissions and get performance, maybe diesel isn't the way forward.
I read a pretty good article here. I would be concerned about your 09 and maybe consider a buy back or just not get it retrofitted if you have that option.
http://www.greencarcongress.com/2015/09/20150921-vw2l.html
