E-Brake won't turn off running lights
Stab
Alliance, NE, USA
This is NOT a DRL debate!!
I have searched the forums for the answer but could not find THIS problem.
I just replaced the battery in my 03 Jetta TDI & it's cold here now so I want to be able to turn the DRLs off with the E-brake application like it used to do. I just disassemibled the e-brake switch under the lever inside the car and reassembled. It turns the brake light on & off in the dash as intended BUT, the running lights are on while trying to start the car WITH the E-brake ON and the dash light indicates it is on. I DO NOT want to disable the DRL. I just want to shut them off with the E-brake while starting.
I apologize if this has been covered but, I could not find it!
CopaMundial
Southeastern PA
03 Jetta Wagon 5sp (New to me Oct 2014) 03 Jetta 5sp (RIP Aug 2014)
Even if you lights were on (e-brake not applied, or switch not working, etc) then the headlights (and all other accessories) should still turn off while starting. If they are not then you have a problem with your load reduction relay.
Lug_Nut
Sterling, MA. USA
2015 GSW 6M in S trim the other oil burners: 1967 two stroke Sonett 1988 Bolens DGT1700
See if the DRL relay (171?) is stuck in the closed contact position. The hand brake simply cuts power to the coil and the internal spring is supposed to open the contacts when there's no electromagnetic coil force to overpower the spring and close the contacts. If the spring is broken, or high current has 'welded' the contacts shut, then the DRL would be on regardless of the handbrake electric circuit state.
CopaMundial
Southeastern PA
I believe the location of the relay Lug Nut mentioned is highlighted in yellow below.
Load reduction relay location is highlighted in blue, in case your accessories are not turning off when starting
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
Yes, but it's nice to have them off during pre-glow period. Especially when/if you live where it gets really cold and when the glow time is VCDS extended, it can be quite a while. I always set the brake to disable the headlights and also turn off all the electrical loads I can (seat heaters, rear defrost, cabin blower fan, etc) before starting the glow cycle when its cold out.
But, you are correct about these things being off during the cranking itself.
jettawreck
Excellent information.:)
Stab
Alliance, NE, USA
Found it, awesome! Thanks everyone for the help!!
It's not a problem running without the #173 relay until I get another is it?
aircooledkid
Was KC now NM
14 328d BMW f31 wagon, 05 reflex silver 5sp wagon, 04 5sp blue anthracite golf, 03 5sp wagon(sold)
Check all you fuses first. I blew one when working on the AC system for my uncles 01 golf. I could not get the DRL's off with the park brake engaged. Cant remember which one, but it fed voltage to the high pressure switch. Worth a shot.
Stab
Alliance, NE, USA
Ok, found the 173 relay and replaced because of burnt points inside. Didn't solve the problem. Checked all the fuses while checking parasitic draw on the battery. All fuses good. It looks like the 173 relay trips when a ground is interduced to the circuit. Via the emergency brake switch....Is this correct? If so maybe I have a ground problem but, it activates the brake light in dash when the handle is pulled and released. Any ideas out there?
fosjef67
VA
2004 Jetta (BEW)
I know turning off the DRL with e-brake on the 04s uses the CAN-BUS. I know this because I blew the CAN-BUS fuse when installing an aftermarket radio. I spent an hour trying to program the steering wheel controls, until I realized DRL were on with the e-brake engaged. Replaced the fuse and the DRL went off, and I was able to program my steering wheel controls.
Also just because a fuse looks good, don't assume it is.
yurtesen
Finland
Golf Variant
I have the same problem in my 2003 Golf with euro switch. The parking brake (e-brake) light works fine on dash.
The headlights (low beam) come on when euro switch is set to 0 position automatically.When I set to parking lights position, they turn off. This tells me that the 173 relay is probably working?
Did you ever find a solution to this problem?
yurtesen
Finland
Golf Variant
@BobnOH yes thats what I understood also but he said changing 173 did not help.
Funny thing, today I looked at the relay box and there is just space where 173 should be. Yet I have DRL functionality and car is 2003 VW Golf Variant MK4. So how is it wired even? Is TFL from light switch directly wired to headlights? Strange...
wonneber
Monroe, NY, USA
I see there are 2 ground wires from the relay.
Pin 1 is to ground.
Pin 3 goes to the parking brake switch and the switch is grounded to shut the lights.
Both grounds seem to go to the same location below the left side of the dash.
I wonder if that ground was bad if power could back feed leaving the running lights on and possibly blowing the CAN-BUS fuse?
yurtesen
Finland
Golf Variant
@wonneber the 173 relay takes running TFL input/output from pins 2/5 and it is isolated from any other grounds and what not. Basically it works as a simple switch.
The rest of the connections are for keeping the switch on unless handbrake is pulled/on when the ignition is turned on.
Also according to the diagram, there are diodes inside the relay ground connections (since it is an electromagnet, it needs them).
But I don't have 173 or I don't know where it is in my car :) strange...
wonneber
Monroe, NY, USA
2 and 5 are the power wires.
Pin 1 is the ground wire.
Pin 3 goes to the parking brake switch and the other side if the switch grounds back at the same point as the other ground, left side of the dash.
I suspect 1 of the diodes is for surge spike suppression from the coil in the relay and the other only lets power go from the dash light go to the parking brake switch for grounding.
eddieleephd
Battle Ground, Wa
2002 jetta Wagon
409 I believe it's another substitute for 173 maybe.
53 is starter relay and the one to the right of 409 is load reduction relay. I don't see your 109 relay either. Where is it?
Sent from my Armor_2 using Tapatalk
yurtesen
Finland
Golf Variant
Continuation reference "e" is connected to T17/7 (TFL pin) on E1 and "c" is connected to 56b (low beam). The relay is a normally closed type relay. So unless handbrake is pulled, low beams are on.
Pin 1 is connected to some resistance and diode for dissipating backflow. The picture is not clear but anode of diode is connected to pin 1 which is grounded. Protection diode is here.
Pin 2 is connected to TFL pin of E1
Pin 3 is connected to parking brake switch. When you pull handbrake pin 3 is grounded. This will turn on the dash led, plus activate the electromagnet in the relay, severing the headlight power through pins 2 and 5 by setting switch to open position.
Pin 6 is connected to the dash led.
Pin 8 is power positive from ignition switch, after fuse 5 (7.5A)
If your relay is stuck in closed position, you would get low beam stuck on when TFL pin is powered, regardless of handbrake position.
If pin 3 is not connected, parking brake warning light won't function and relay will be stuck in closed position
If ground 1 is not connected there can be some backflow but it should not damage anything as far as I can tell (perhaps can damage only the 173 coil itself?). You won't get a blown fuse from such a tiny coil.
yurtesen
Finland
Golf Variant
See:
http://web.mit.edu/dennis/www/vw/relays.html
Yes, well my car is not exactly a TDI... it is a petrol engine model. So I have 409 and not 109. You can see it from the list in the page above.
eddieleephd
Battle Ground, Wa
2002 jetta Wagon
Makes sense now, still need to look at the circuit involved with fuse 14 and the relay that supplies power to it. Whatever circus is involved with it.
yurtesen
Finland
Golf Variant
@eddieleephd what about fuse14? Manual says it gets power from "Threaded connection -2- (30) on the relay plate" with a thick red write (6mm2) to fusebox. The output is connected to "Central control module for comfort system, behind instrument panel. left" with a red/black wire (1mm2) to a pin 22 of a terminal with 23 pins (T23/22)
Same thick red wire feeds fuse 238 also apparently. The output is red/yellow wire (1mm2) and connected to "Plus connector (30a). in wiring harness interior" That current track seem to be connected to driver/passenger side door control modules....
Does not seem to be related to headlights? :)
eddieleephd
Battle Ground, Wa
2002 jetta Wagon
You said that when you pulled that fuse the lights were able to be controlled correctly by the brake switch, therefore, some circuit that's getting power from that fuse has a fault in it causing the issue. Could be the relay ahead of it which is unlikely. So you need to find out what gets power there and run those circuits down to find the fault.
yurtesen
Finland
Golf Variant
No, I did not say anything like that. Also MK4 does not have CAN bus AFAIK? (or at least it is very limited I think).
It looks like it is on MK5 where the DRL is controlled via central electronics module.
fosjef67 mentioned a CAN bus fuse but he didn't mention a fuse number?
Anyway, it seems unrelated. I simply do not see, to have relay 173 and my car does not have central electronics module as far as I remember :)
csstevej
north nj
2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,glutton for punishment got another tdi 2001NB,another yellow tdi NB , added an 06 NB DSG
You realize that he posted this 7 years ago?
