Dynaudio amp swap for VW amp (POS)
williamgd2
West Hartford Ct
2010 Jetta
I think there going under bad or NO customer service is a tell tail sign.Paypal told me that they are going to stop taking payments for them because there are many other's with problems. Don't buy from Naviservice.com.pl unless you want to loose your money.
Sootman
Maine Coast
2011 Golf TDI
I currently have a Premium 7 HU with the 6-disk changer and Sat radio, but no navigation. It also had the 1K6 035 456 unit under the driver's seat that I've swapped out with the 3C0 035 456 C. I can't find a way to recode the radio settings (57) using the VagCom to update to Dynaudio setting. Do I need to change my HU to something like the RNS-510 or will it be all set with the current HU? Or is there another way to recode the current HU?
D-Cell_Mekanick
Sandwich, IL
2015 Honda Civic SE
I just swapped the amps, no recoding needed for my amp. I also have the silver button premium 7 radio.
Sootman
Maine Coast
2011 Golf TDI
Thanks for the reply. Maloosheck was kind enough to give me a code that went in fine and the amp appears to be working well. Speakers next?? I'm going to start searching the junk yards.
KevinR
Georgia, USA
None
I stumbled on this thread as I was doing research for a possible car purchase.
Just an FYI for those people trolling the junk yards for speakers: Many Volvos, particularly the '98 to '04 C70s, are factory fitted with Dynaudio speakers. In the case of the C70, look for the cars that have a raised speaker grill on the center portion of the dash.
It would probably take a bit of creative fitting, but it might be an alternative if you have a hard time finding the VW specific parts.
chiro05
KY
2006 Jetta TD I
If I wanted to call the local salvage yards, which car does this amp come in? Is it even possible to find it?
bhutchins
SW Portland OR
Jetta TDiCup, 02Q built Sept 2010
Dynaudio
The CAN BUS monitors the impedance of each individual speaker, and you will have error messages. also the dynaudio amp is a 10 ch DSP amp, matched to the speakers and sound space. Mine is the whole package out of a CC
Sootman
Maine Coast
2011 Golf TDI
No error message here using the dynaudio amp in my '06 pkg 2. A class D amp should easily be able to handle a range of impedances. I doubt my sound system is a 10-chanel unit. My next move is to find an RCD-510 and get that in the car or a new Escort radar detector. The Escort is probably cheaper in the long run:D
chiro05
KY
2006 Jetta TD I
What model vw's and what years should I be looking for if I wanted to scavenge salvage yards for the amp?
williamgd2
West Hartford Ct
2010 Jetta
Good luck looking
The salvage yards know theres a huge market for these amps and it would probably be one of the first things removed.I don't know what years to look for but you could look for the dynaudio speakers then look for a amp.
chiro05
KY
2006 Jetta TD I
I live in the sticks, not sure many around these areas would even care.
maloosheck
Sterling, VA
2K6 1K2 BRM, 2K8 7L6 BWF, 85 16 MF
Salvage yards have no clue what each module is doing...
williamgd2
West Hartford Ct
2010 Jetta
Well I have been big on ebay for years and can usually find anything except a vw dynaudio amp.Any other brand of amp Vw installed you can easily find except the Dynaudio.
chiro05
KY
2006 Jetta TD I
I think I will just wait til sat radio subscription is up and then just go aftermarket on the head unit and amp.
VDUB2NV
Longview, WA
2005.5 Jetta TDI PKG2
Its good to hear that you finally got your money back. They probably found out the real reason that their business has dropped off was you telling people not to deal with them.
williamgd2
West Hartford Ct
2010 Jetta
I did spread the word all over the internet and then I found them trying to sell on a few audi forums and I joined just to tell people. I think that is why they finally sent me a refund.
jellvand
Belgium
Skoda Superb 2.0 cr 170
1Q0 035 456C for sale
Hi guys,
If anybody is interested, I have an amp from EOS ( 1Q0 035 456C) for sale for € 350. Bought it for my Skoda Superb, but gave up on the installation as it's a completely different wiring in my car.
Send me a PM if you're interested.
jellvand
Belgium
Hi guys,
klrman
MN
2010 Jetta TDI Cup Street Edition
Selling NIB Dynaudio Amp 3C0-035-456-C
Part #3C0-035-456-C. New, never installed. Please see my eBay auction under user "mitchtombay".
Also auctioning a matching Naviservice wiring harness for the RCD-510 and some other associated items.
Thank You.
WILYDIESEL
WA
05.5 JETTA PK2
Dyn amp wtb
alnmike:
It's hard to say if your specific car has the (drivers seat, viewed from front) external VW amp model 1K6-035-456-A.
The VW 1K6 model is the amp in my MY06 Jetta TDI Pkg2 w/MFD2 DVD Navi and DSS (digital sound system) option as built in August 2006.
It was an easy plug n play swap with the new Dynaudio amp model # 3C0-035-456-C amplifier. Simply unplug the amp then rotate the two multi pin connectors 180 degrees, then connect the Dynaudio 3C0 amp. BINGO.... real HiFi in the Jetta. Made all the difference in the World.
Audio speaking:
Greater sound pressure level (SPL), Real stereo image, linear bandwith with detail, low distortion, very dynamic sound staging,,, something my optional, extra cost, ordered new VW DSS HiFi didn't have. The new Dynaudio amp alone makes the Jetta TDI stereo a pleasure to listen to. Can't wait for step 2 and source the Dynaudio drivers. Then again, why bother its now that improved. - In my case I've already started casting round for the Dyn drivers.
Do remember this optional HiFi stereo system is active, not passive. Big, huge difference!
Run don't walk if your Jetta TDI with external amp is a suitable candidate...
Hello, I have a 05.5 pkg 2 and am impressed by your success. Can you tell me of any dyn amps available? I know it is unlikely but thought I would give it a shot, thanks, J.
450
Ohio
None. 01 EV
I have a Dynaudio Amp, however the problem is that I don't have the requisite wiring.
So I'm going to try to retrofit the whole thing in my car, but I'm not completely sure where to start with the wiring. I don't know where I can get a harness and I'm not sure how to make the wiring myself. Specifically what type of wire to use and where to get the connectors.
325_Guy
West Central Texas
MkV Jetta
Bump! These amps are now rarer than hens teeth. Anybody who bought one six years ago for $11 willing to let one go?? [emoji23]
Cabriolet26
uk
golf r
If you look at my picture here: http://furmanka.blogspot.com/2009/12/mk5-dynaudio-gosniki-dynaudio-speakers.html
You will see that the plugs are the same for all the amps: Jetta DSS and EOS Dynaudio. And the same as Passat Dynaudio above.
Re the plug outs for Dynaudio retrofit . What pins are used for the from tweeters and what pins for the subwoofer
Picked up your posts . Re pinouts on Dynaudio amps I am struggling to find which pins take a signal to a unpowered subwoofer.
This was a an option in a TDI golf for a Dynaudio setup with front left and right speakers and separate tweeters in front doors together with a rear left and right speakers. A separate similar sized speaker is situated in one of the door at the rear and this is termed the subwoofer . There is the separate Dynaudio amp with pinouts as per your post.
Currently the car has standard front left and right speaker, and separate front and left tweeters . In the Rear I have rear left and right speakers , no tweeters no subwooferr or Amp.
I am retrofitting Dynaudio and have everything I need. My question is what pinouts do I use to connect the additional subwoofer. Similarly do I leave the rear tweeter pin outs unconnected or link them to jointly connect to the rear speakers.
Any help appreciated
Cabriolet26
uk
golf r
Putting full set up dynaudio into my golf r cabriolet , it was not an option but was fitted to GTI, cabriolet . It’s a mark six . Everything is a straiget replacement just the amplifier wires from head unit in and wires out to dynaudio speakers , straight replacements . The head unit is the rns 315 .
the only addition is a subwoofer in one rear panel where I have source the correct fitting pane .
my question is how do I wire the subwoofer . Is it from the dynaudio out pins if so what pins , or is it directly from the head unit . I cannot find pin in or outs diagram which take a subwoofer . Any help appreciated .The subwoofer speaker by the way is not powered but an extra dynaudio single speaker . Thanks for any input.. a suppose a general question also may answer , where does dynaudio get a bass signal to an unpowered speaker or the same question if from an rns bass unit .
